R56 Windshield (cowl?) cracking
Old Sep 29, 2019 | 06:46 PM
Bill-SD's Avatar
Bill-SD
I just noticed that my cowl (I believe that's what it is called?) is starting to crack and fall off. It appears that I have to replace the whole piece, and not just the rubber section. Any suggestions on where to purchase a replacement? And maybe a DIY on replacing it. I'm guessing it a pretty straight forward project.
Old Sep 29, 2019 | 07:04 PM
mini-is-for-me's Avatar
mini-is-for-me
Mine is completely broken off. It is much worse than yours. It is up to you but I will not be replacing my entire cowl over that rubber piece. That's dropping a dime right there.
I'm thinking of going to go with something like this:
https://www.ebay.com/itm/Car-Ageing-...EAAOSwtbxbq6n5
Or this:
https://www.ebay.com/itm/120-Rubber-...AAAOSwVDpc0nFU
This might be the real stuff?
https://www.ebay.com/itm/MINI-OEM-02...AAAOSwXXxZRG6T
I don't have enough left to tell how "it use to look".
Old Sep 29, 2019 | 09:07 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Pretty normal as we see them all come apart.
Go to your local dealer and pick it up as they are large parts and often damaged during shipping so it's not cost effective to ship them.
Old Feb 11, 2020 | 02:19 PM
seandallen's Avatar
seandallen
I replaced mine. The parts aren't terribly expensive. I would suggest ECS Tuning for where to buy. It takes about 30 minutes to change them out. I thought it was an easy fix to sharpen up the look & I expect they'll last another 10 years or so.
Old Feb 11, 2020 | 04:40 PM
AZdsrt's Avatar
AZdsrt
When I had the windshield replaced, the installer simply trimmed off all the pieces that were cracked.
Old Feb 12, 2020 | 06:17 AM
mini-is-for-me
I just trimmed off the old one and bought the trim on Ebay for $3 and then glued on the new one with clear window sealant (the aquarium kind). It will now last forever. If you buy a new one, it will be of the same poor material quality as the original. The Ebay trim is heavy duty and is not going anywhere for the rest of the life of the car.
Old Feb 12, 2020 | 10:07 AM
mildensteve's Avatar
mildensteve
Same here except now they are about $9. Not sure why the price jump.
Old Feb 13, 2020 | 03:38 AM
Crossingover's Avatar
Crossingover
Is there a functional/practical reason to maintain the rubber strip?
Old Feb 17, 2020 | 06:02 AM
mini-is-for-me
If you search for it as a "replacement for a mini cooper S", you get the $9 version. If you then take the words and search for a generic rubber strip that is similar, you see the same material sold without respect to the Mini, and sells for a lot less. You have to buy the stuff from China as well and it takes a month to get here.
Old Feb 17, 2020 | 06:04 AM
mini-is-for-me
It's a good question, it seems to me the water that goes underneath this strip just goes behind the engine, in front of the firewall onto the ground.
Old Feb 17, 2020 | 10:54 AM
mildensteve
Not so much the rain as keeping the stuff (like leaves, twigs, etc.) that falls down on the windshield from getting into the cowl area, under the plastic. Unless you want to remove the plastic (which requires wiper arm removal) and clean underneath frequently.
Old Feb 19, 2020 | 10:22 AM
Thats and junk ending up in the cabin filter.
Old Feb 21, 2020 | 09:17 AM
david_foster's Avatar
david_foster
I ended up fixing mine which stopped the water leak into the passenger footwell.
Old Feb 21, 2020 | 10:13 AM
Lipofskyphoto's Avatar
Lipofskyphoto
Get one at a used parts yard.
Old Mar 10, 2020 | 10:43 AM
Bill-SD's Avatar
Bill-SD
So I bought the replacement cowl pieces. It seemed like a simple project to replace them so I went out to do it this morning. I had a problem right off the bat. My wiper arms are stuck! I tried wiggling them but not luck. I'll go out later and pick up some penetrating oil and see if that helps. Anyone have any other suggestions on how to remove the arms?
Old Mar 10, 2020 | 10:47 AM
Lipofskyphoto
it's not necessary to remove the wiper arms. I just removed my cowl pieces without doing so. Just work slowly and carefully
https://www.pelicanparts.com/techart...eplacement.htm
Old Mar 10, 2020 | 10:55 AM
https://www.northamericanmotoring.co...ield-cowl.html
Its the other side when you do the whole cowl.
Hit it withe some free all and let sit or get a wiper arm tool.
https://www.ecstuning.com/Search/SiteSearch/wiper_tool/
Old Mar 10, 2020 | 02:41 PM
david_foster
My wiper arms were "stuck" when I first tried to remove them too. I might have it wrong, but they released fine when I pulled them fully up. I tried testing it out, and when the arms were flat on the glass, they would not come up. When they were pulled fully up (so bent as much as the hinge would allow), they slid off easily.
Old Mar 11, 2020 | 07:30 PM
Bill-SD's Avatar
Bill-SD
A wiper arm puller did the trick!
This whole "quick" project has been a pain in the butt though. I can't get the new pieces to sit very flush with the windshield. The rubber piece that was glued along the bottom of the glass keeps sliding when I put the new cowl pieces on. I got it close...but not close enough for my liking. Anyone that's done this before know a trick for that? I messed with it for over an hour. I'll try it again tomorrow.
Old Mar 12, 2020 | 06:16 AM
Thats great the tool worked.
On that trim siting flush, the botom side of the plastic
Need to fit all the way in on the bottom window rubber strip, 51312756196
More info here
https://www.northamericanmotoring.co...ld-cowl-3.html
Old Mar 12, 2020 | 06:39 AM
Bill-SD's Avatar
Bill-SD
More info here
Thanks for the tips. I going to take it back apart today and make sure everything is lined up. I didn't replace that bottom strip but it seems fine...just a little sticky and gooey.
Old Mar 12, 2020 | 10:09 AM
Bill-SD's Avatar
Bill-SD
After taking a break before trying again, I was finally able to get this to fit snugly. Thanks again for the help!
Old Mar 12, 2020 | 10:10 AM
Glad to help.
Old May 5, 2020 | 11:37 PM
flatlander_48's Avatar
flatlander_48
I would also worry about water getting into places where it shouldn’t be, freezing and then forcing things apart...
Minipapa
Mid-Ohio Motoring Club
40
Apr 20, 2009 01:17 PM
Ms.Emma
12
Nov 25, 2008 11:52 AM
speedmini
Jul 7, 2008 11:13 PM
dbsanford
Mar 2, 2008 09:07 PM
