Sun Damage Windshield Cowl
Old Jul 23, 2015 | 11:27 AM
  #51
AMTAG's Avatar
AMTAG
Mine is doing it too but just ordered the replacement from ECS :P
Old Jul 23, 2015 | 11:49 AM
  #52
Thanks for the order.
Old Nov 13, 2015 | 02:02 PM
  #53
Seaswood's Avatar
Seaswood
Just installed the brake reservoir side, batter side was replaced couple years ago.
& windscreen was replaced this summer.
The battery side will not lock in, there is a missing lock on the corner of the car side.
But is that an indication I need to replace the plastic under the wind screen?
Seems so.
Old Nov 13, 2015 | 02:11 PM
  #54
Its pushes into the seam towards the seal up against the window for the back connection facing the glass,the other two are of course a screw and a nut.
See a page back:
https://www.northamericanmotoring.co...ld-cowl-2.html
The hard plastic portion goes right below in the lower gasket near the windshield.
Old Nov 13, 2015 | 04:22 PM
  #55
Seaswood's Avatar
Seaswood
I think that means I need the strip that is under the window is worn. Where those two bits grab in the rear of the the installation out of sight.
Old Nov 14, 2015 | 09:09 AM
  #56
gpzjack's Avatar
gpzjack
I cracked mine installing gauges. Just got a new one. I think it was $42 shipped on ebay. Not too bad
Old Nov 16, 2015 | 07:19 AM
  #57
If the strip under the cowl on the lower of the window is torn or damaged it's here : 51312756196
https://www.ecstuning.com/Search/SiteSearch/51312756196/
It slides and holds on the bottom of the window with that slot facing up.
Old Feb 8, 2016 | 07:11 PM
  #58
Val P's Avatar
Val P
Question
When I searched through your website, I noticed there are several cowls for mini listed there.
https://www.ecstuning.com/Search/Sit...owl/ES2762310/
https://www.ecstuning.com/Search/Sit...owl/ES2581934/
https://www.ecstuning.com/Search/Sit...owl/ES2762309/
Can you tell me which one is the right one for me? I just want to be sure which one is right for my MINI before I order it.
I have a 2008 MINI Cooper S.
Thanks in advance.
Old Feb 9, 2016 | 05:01 AM
  #59
Thanks in advance.
Hello,
You can use the drop down menu here to find your model and what fits.
For a 2008 MINI Cooper S Hardtop = R56 Chassis 51132751209
Also fits R55 MINI Clubman Gen 2 2008-2014 , R57 MINI Convertible Gen 2 2009+.
https://www.ecstuning.com/Search/51132751209/
This one is R58 MINI Coupe' & R59 MINI Roadster ( Gen 2) 1712758793 KT
https://www.ecstuning.com/Search/SiteSearch/1712758793KT/
MINI Countryman , MINI Paceman ( Gen 2 ) 1719808095 KT
https://www.ecstuning.com/Search/SiteSearch/1719808095KT/
Thanks and let me know if you need anything else.
For your R56 2008 MINI Cooper S ( hardtop ), here is the drop down in car:
https://www.ecstuning.com/Mini-2008-Cooper-R56-S-Coupe-L4_1.6L_N14B16A/
Old Feb 9, 2016 | 06:50 PM
  #60
Val P's Avatar
Val P
Hello,
https://www.ecstuning.com/Search/511...aign=postreply
Thanks for your response; I think what got me more confused was this part on the website:
Anyways, I should have waited for your response, I ordered this one last night:
https://www.ecstuning.com/ES2581934/
So it looks like I ordered the correct cowl kit. I'll let you know if any issues.
Old Feb 10, 2016 | 05:37 AM
  #61
Yes that's the one, please use our drop down menu as there is a glitch in the fits section on some items and it shows MINI all. We are working on fixing this.
If you need anything else I am always here to help.
Old Feb 13, 2016 | 11:34 AM
  #62
Val P's Avatar
Val P
Package arrived
I just received mine today. Going to try and install it tomorrow. Looks like I'm going to have to remove the windshield wiper arms to do it, which I have no clue how to do
Old Feb 14, 2016 | 09:25 AM
  #63
Val P's Avatar
Val P
Done
Just finished installing it. It feels like a brand new MINI.
This is one of the cheapest things you can buy for a MINI and anybody can do it at home.
I also replaced the cigarette lighter socket and now it doesn't jiggle.
Old Feb 15, 2016 | 08:40 AM
  #64
Great, looks like you got it fitted right, makes a big difference in the front end appearance I believe.
Old Jun 5, 2016 | 01:35 PM
  #65
MINI8K's Avatar
MINI8K
I got the same problem & it's all starting to peel off.
2 questions:
1) Do the cowls come with the molding attached as one piece? So 1 is part of 4 or is 1 this separate mounting strip (51312756196)?
2) If 1 and 4 are separate, could I just get 1? The cowls are fine, it's just that mounting strip/molding that's cracking & breaking off.
thanks
Old Jun 5, 2016 | 01:46 PM
  #66
Val P's Avatar
Val P
2 questions:
thanks
If you buy the kit I purchased, you will be getting everything together. The image you posted is just a description, but it's essentially 3 parts (left and right side). The battery cover is attached to the right side cowl, so you don't have to install it. The "strip" (#1) goes underneath the cowls and it's optional unless yours is damaged.
Take a look at my images I posted before.
Old Jun 5, 2016 | 03:27 PM
  #67
MINI8K's Avatar
MINI8K
Great, thanks!
Old Jun 6, 2016 | 06:50 AM
  #68
As posted above #54 post and what also Val P stated the Rubber seal to the window is parts of #3 and #4 and is bonded to the edge and in the kit.
Old Aug 24, 2016 | 05:31 PM
  #69
BlackIce's Avatar
BlackIce
Just noticed that lower rubber seal along the bottom of the windshield is cracking and chunks are missing on my 2012 MINI Cooper Hardtop R56 Justa. Guess I need to replace it like the rest of you, but a little confused on the last couple posts.
ECSTuning - You say above that the rubber #1 is "bonded" to the pieces #3 & #4, but in your post #57 you list the rubber #1 for sale by itself.
All my plastic pieces are just fine, it's just the rubber strip that is bad. Is item 51312756196 the right rubber piece to order for a 2012 MINI Cooper Hardtop R56 Justa?
If the other posters are correct, the rubber piece is held in place by the OEM plastic pieces #3 & #4 with a lip of plastic going into a grove in the rubber. Correct?
Mnay thanks for clarifying.
Old Aug 24, 2016 | 07:57 PM
  #70
Val P's Avatar
Val P
This might help.
Ignore the numbers here, they are the same part.
This is one part.
#1 in this picture goes actually under the glass and of course under the cowl.
That thing that looks like a strip is used to hold the glass from hitting the frame and water from spreading underneath the cowl.
Old Aug 25, 2016 | 10:48 AM
  #71
Yes, the full kit is what you need as it has that bonded rubber that cracks and peals.
#1 is the rubber time that goes under the cowl and you don't see it. Its replaced most of the time with a front windshield replacement
Old Nov 16, 2017 | 06:29 AM
  #72
Just an update, we have the R55-R57 and The R60-R61 linked above kits back in stock with free shipping.
Old Mar 11, 2018 | 03:54 PM
  #73
johnjx5's Avatar
johnjx5
I ordered the cowl from ECSTuning and mine was broken as well. Seems like a fragile piece as noted earlier.
I attempted to repair using this:
It seemed to bond quite well but then it re-cracked while fitting the piece.
Old Mar 12, 2018 | 05:56 AM
  #74
Sorry to hear that, the shipping companies can knock those ends around a bit. Let us know if you ever have an issue and our customer service can help you out. I am always here and just a PM away.
Glad you were able to mend it.
Old Mar 15, 2018 | 11:23 AM
  #75
chimivee's Avatar
chimivee
Passenger side won't sit flush
I just replaced both sides of the apron and have the same issue with the right side panel not laying flush where it meets the left side panel in the middle. I can push it down, and it sorta "pops" into place, but simply pops back up when I let go. The lower windshield seal was pretty trashed and was not staying in place well, and presumably not allowing a good interface with the new apron. So...
  1. Do I understand correctly that replacing this part should fix this problem and allow the apron to sit flush?
  2. Will I have any issue removing the "new" apron that I just installed without damaging it? (when I pulled the old one, it was a very tight fit and some of the tabs broke in the process)
Side note: My original d/s piece also arrived from ECS with a broken corner, just like the photo above from another poster. It was not packaged well to protect the corner. ECS kindly and promptly sent a replacement (THANKS!), but unfortunately, that one was also damaged in the same place, although to a lesser extent. Rather than go through another return, I used some trim adhesive to glue it together.
