Can't Unbolt Crankshaft Pulley!
It's time for me to replace the crankshaft pulley in my r55 as its gotten rusty and more importantly it has just the slightest wobble on it. When I was reading online people made it sound easy when they said that you just unscrew the three torx screws and pop it off. I guess the crankshaft pulley has never been replaced on my r55 because I can't manage to unscrew it at all! Not only is the whole thing turning as I'm turning, but when I manage to have it stop I cannot get the screws to move at all.
Has anybody else run into this problem before? I just wanted to know if there's something that I'm missing or if I'm just gonna have to give it my all with getting the screws off.
Also, is there a better way to get the crankshaft pulley to stop rotating? I'm no mechanic by any means so I'm learning everything along the way hahah
First of all, are you trying to change the pulley (center bolt) or the vibration damper (three torx bolts)? Take a look at this illustrated parts list to be sure which you want to change --- https://www.realoem.com/bmw/enUS/select
Then take look at these procedures --- https://www.realoem.com/bmw/enUS/select --- and find the one most appropriate for what you want to do.
Note the special tools required for the pulley, and the requirement to reset the timing, a major chore and NOT recommended for the novice mechanic.
No need to be sorry, I was wrong about the function of the damper. I was in a hurry this AM. My bad!
Damper bolts can be removed using the flywheel locking tool that's part of most timing tool kits. It's also possible to use the center bolt to hold the crank in place while torquing the three VB bolts, but not recommended. If the center bolt should loosen, you're at risk for blowing the entire engine. Definitely find some way to lock the flywheel.
For me there are few easy ways to do this, all of which work very well.
Method 1: use a strap style oil wrench and wrap it in the correct anti-torque direction. I've attached a link to an example here: https://www.grainger.com/product/52V...!502447222717!
This is the easiest and never had once failed. If you watch some youtube videos on how to remove the A/C clutch pulley on BMW's, you'll get a good idea.
Method 2: Obtain the key lock from the timing chain alignment tool, insert the key lock to the flywheel at TDC position, by then you'll easily be able to remove the dampner bolts.
Method 3: Special tool, I'd advise against this as the tool is quite expensive, and you won't seem to use it too often. Or you can try to fabricate one like many others have done.
And, might I add loctite might be in use.
If it is that tight, you may need to use some heat before it breaks free.
Drivetrain Crankshaft Pulley = really Bad idea...
OldRick
Aug 3, 2011 04:24 PM
Mark
Site Feedback
Nov 11, 2005 07:04 AM
juzmackjr
Nov 26, 2004 08:28 PM
