Drivetrain Crankshaft pulley...
Old Oct 16, 2004 | 04:59 PM
RECOOP's Avatar
RECOOP
What can I realistically expect from installing one of the lighter crankshaft pulleys on my MCS? Thanks...
Old Oct 17, 2004 | 01:34 AM
D1JL's Avatar
D1JL
I'll let you know Tuesday.
Dave
Old Oct 17, 2004 | 05:01 AM
jlm's Avatar
jlm
expect to damage your engine from un-damped torsional and and lateral vibrations inherent to the inline 4. try the search function.
Old Oct 17, 2004 | 07:19 AM
rajron's Avatar
rajron
Not sure if this applies but something to consider.
http://dinancars.com/whitepapersFile.asp?ID=5
Old Oct 17, 2004 | 07:29 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
If you are seeking a quicker-revving engine, you'd gain more of a benefit from using a lightened flywheel first. Use the pulley as a last resort, and not on a car that will be seeing primarily street usage. The stock damper incorporates a system which prevents torsional vibrations from affecting the supercharger and other accessories.
Also, if the light crank pulley is any smaller in diameter, you will lose boost and subsequently power as you'll be turning the supercharger slower instead of it's current speed or faster.
My latest 'worry' regarding this mod is a result of seeing threads pop up regarding belt tensioner failures. Adding the solid pulley will markedly increase the torsional vibrations transmitted to the belt and the 'whipping' effect the tensioner already encounters. Just a thought.
Old Oct 17, 2004 | 08:53 AM
jlm's Avatar
jlm
the Dinan ref is spot on
Old Oct 17, 2004 | 12:12 PM
RECOOP's Avatar
RECOOP
Crankshaft pulley
Many thanks for the comments and the Dinan reference :smile: . You've helped me to change my plan to leave-well-enough-alone! Since I already have a 15 lb. flywheel, it seems that the lighter crank pulley could be courting disaster . BTW, jlm, I did try the search function before posting, but was unable to find any threads on NAM. Perhaps I did it wrong...
Old Oct 17, 2004 | 02:31 PM
jlm's Avatar
jlm
I thought there were a couple of posts a few weeks ago about the lightweight pulley; so:
I just searched on "harmonic" and found a few:
https://www.northamericanmotoring.co...light=harmonic
Old Oct 15, 2008 | 03:48 AM
norm03s's Avatar
norm03s
Update
The above link isn't working anymore, try this;
http://www.dinancars.com/bmw/technia...armonic-damper
Old Oct 15, 2008 | 04:33 AM
D-MAN's Avatar
D-MAN
There is no conclusive evidence that lightened crank pulley's cause oil pump failure or any other engine damage!
There are so many sold worldwide to a lot of mini owners, and if there were issues I am sure there would be more cases of blown up engines around the world.
There are also alot of people with crank pulleys that have done a lot of miles and had no issues!!!! https://www.northamericanmotoring.co...=54503&page=10
I think it is a very simplistic approach to blame mechanical failures on non-dampened crank pulleys.
Bottom line is it is up to people to make informed judgements on what they may or may not put on their car!
I will now put my flame suit on, sit in the corner and wait for a roasting...
Old Oct 15, 2008 | 04:36 AM
D-MAN's Avatar
D-MAN
I thought the only aftermarket crank pulleys available were either stock size (0%) or larger?
patsum
26
May 29, 2021 06:29 PM
tr3y003
33
Jun 5, 2020 05:00 AM
fkrowland
Sep 30, 2015 10:30 AM
lifeofjenn
19
Sep 24, 2015 11:01 AM
Sep 3, 2015 02:06 PM
