R52 Convertible Glass Window Detaching From Frame
Old May 31, 2019 | 12:19 PM
rauls4's Avatar
rauls4
I am surprised I have not been able to find some info on how to fix this. The glass is popping out of the plastic frame at the bottom. I think it's held at a bit of tension because simple re-setting it into the groove does little as it pops out again.
I assume I need to probably do a full removal/cleaning/reattachment, However I have no idea what products to use or if I will need some of those suction windshield holders.
Does anyone know of a DYI document or site to tackle this?
I found some videos online but they are for R57s which don't use the plastic frame.
Old Jun 1, 2019 | 06:03 PM
ItsmeWayne's Avatar
ItsmeWayne
There is a tool for tightening and adjusting door windows:
Amazon has one for $30, but you can find them cheaper on the site or Ebay and some local auto parts dealers!
Old Jun 1, 2019 | 11:40 PM
rkw's Avatar
rkw
The OP is referring to the rear window of a convertible roof.
In the videos you found for the R57, the owner improvised a fix using available products. You'll need to try as well, using similar adhesives and sealants.
The official MINI/BMW service manual (used by dealers) have no instructions for servicing the rear window (both R52 and R57). A dealer would replace the entire soft roof, which comes with a window bonded to it:
https://www.newtis.info/tisv2/a/en/r...le-top/ER1sNR0
https://www.northamericanmotoring.co...g-unglued.html
https://www.northamericanmotoring.co...placement.html
Old Jun 3, 2019 | 06:43 AM
rauls4's Avatar
rauls4
It really sucks that you can't just buy a replacement window. If it were ever to crack it would cost about $3K to fix instead of a couple hundred bucks.
I think I will try some strong silicone adhesive. I am glad it's not an R57 or later where you have to adhere the canvas directly to the glass, which sounds like an absolute nightmare.
Old Jun 3, 2019 | 07:35 AM
Other the regluing the top to the fabric, which they posted above, it requires a new top. I guess you could try with the insurance company?
https://www.northamericanmotoring.co...w-rag-top.html
genik
Feb 17, 2013 08:54 AM
blrae
Mar 8, 2012 06:12 AM
jeffm5150
Classic Mini Talk
Aug 28, 2010 09:31 AM
PaulMC
Suspension
Jan 12, 2008 11:25 AM
Coop d'etat
Suspension
Jun 15, 2006 06:21 PM
