loud exhaust leak after spirited driving
Old Apr 25, 2019 | 06:48 AM
frankiev's Avatar
frankiev
03 MCS . I curently have a stock exhaust manifold with a WMW exhaust ( sounds great btw ). I had noticed a very small exhaust leak over the last month or so but today I was driving home and during some "spirited " driving the exhaust leak went from a wisper to a shout ..lol
I havent looked underneath yet as its super hot right now . I thought it might be prudent to see where the most common place for leaks might be before I crawl under to look.. Thanks in advance for any help/advice
Old Apr 25, 2019 | 07:01 AM
Check the exhaust manifold/header, https://www.northamericanmotoring.co...-manifold.html
Old Apr 25, 2019 | 07:06 AM
MINI33342's Avatar
MINI33342
Flex connector or pre-cat weld......
Old Apr 25, 2019 | 07:27 AM
frankiev's Avatar
frankiev
thanks guys . Other than it being noisey is it ok to drive ?
Old Apr 25, 2019 | 08:27 AM
Minibeagle's Avatar
Minibeagle
yes. It's okay to drive.
Old Apr 25, 2019 | 08:53 AM
frankiev's Avatar
frankiev
Great thx ..
Old Apr 25, 2019 | 09:45 AM
frankiev's Avatar
frankiev
Things just go really wierd . Started up the car and the exhaust leak was very evident . Turned onto the main road and... the leak disappeared completly ... normal exhaust ... at least until I accelerated again then noise came back . It disappeared again on the way home .. WTF ???
Old Apr 25, 2019 | 09:55 AM
DeadErnie's Avatar
DeadErnie
Wouldn't hurt to check your motor mounts. Old mounts will cause excessive motor movement.
Old Apr 25, 2019 | 10:04 AM
frankiev's Avatar
frankiev
Replaced them all about a year ago but Ill check that nothing came loose ..thx
Old Apr 25, 2019 | 11:37 AM
Minibeagle's Avatar
Minibeagle
The engine rocks back quite a bit under load when accelerating hard through the gears or when repeatedly stabbing the throttle hard, like during autocross. This rocking motions gets transferred to the exhaust system which can results in cracks in certain of its portions (flexpipe, etc.). This happened to me during an autocross event. Got the cracked exhaust pipe welded and installed lower engine and transmission mount stabilizers by Powerflex. Has been trouble free since then. The only thing is that I get more vibration at idle when the AC compressor is running, but I can live with that.
Old Apr 25, 2019 | 12:33 PM
gumbedamit's Avatar
gumbedamit
Read this thread, Your symptoms sound similar to mine:
https://www.northamericanmotoring.co...ml#post4465695
Old Apr 26, 2019 | 06:02 AM
frankiev's Avatar
frankiev
Thanks guys . I went under to take a look and it seems the place where the flex pipe meets the flange of the cat completely seperated . Hoping i can get it welded today
Old Apr 26, 2019 | 06:04 AM
frankiev's Avatar
frankiev
Originally Posted by gumbedamit
read this thread, your symptoms sound similar to mine:
exactly !!!!!!
Old Apr 26, 2019 | 06:20 AM
gumbedamit's Avatar
gumbedamit
Originally Posted by frankiev
exactly !!!!!!
Make sure you mark the two pieces before you take it off, that way you can be precise about the alignment when you get it welded.
Old Apr 26, 2019 | 10:24 AM
frankiev's Avatar
frankiev
Didn't have to remove anything . Took it to a great muffler shop in Hollywood fl . Welded it up in place . Took 20 min and cost 20$.
DrivingMyMini
Apr 30, 2012 11:34 AM
unclemeat
Aug 11, 2010 12:26 PM
200-OK
Dec 16, 2006 12:14 PM
Soul Coughing
Dec 23, 2005 01:18 PM
2Cool
Jul 31, 2004 04:22 PM
