R52 Convertible top problem- inoperable
Old Apr 11, 2019 | 05:21 PM
sci2000's Avatar
sci2000
05 Mini convertible. Top is stuck about 1 inch from total close. Sunroof motor turns about 1 and 1/2 turns via power button or manually with allen wrench. I see movement in latching mechanism on both sides but sunroof section will not move in either direction. I can manually open latches and manually get top up about 8 inches, then it stops. Also have failed quarter window mechanism but can't get assy out without getting top open. Any help would be greatly appreciated
Old Apr 12, 2019 | 06:09 AM
Hello, Check this out for the top cables and motor. my guess is either the cables are broken or stuck and damaged by the teeth on the motor. You will have to pull the motto and inspect the cables. If the cables are not separated or damaged from the teeth of the motor, its possible the that motor in the center of the convertible top is bad. On the rear windows they only dip down after the sunroof portion sides all the way back, then they dip for the top to completely open.
Cables:
https://www.northamericanmotoring.co...tible-top.html
Motor for sunroof portion of the convertible top.
https://www.northamericanmotoring.co...-position.html
Old Apr 12, 2019 | 09:50 AM
sci2000's Avatar
sci2000
Thanks for the reply. I already unbolted the motor. The motor gear and cable worm gears are fine and the motor runs fine. The cables move freely and you can see them start actuating the drive mechanism but they stop after about one turn when they are supposed to move the sunroof in either direction. My guess is the sunroof slider is jammed and will have to disasemble at this point.
Old Apr 12, 2019 | 12:04 PM
Welcome sounds like its jammed or something in the rail is hung up. Yep you will have to take the covers off the sides and look at the mechanics
Old Apr 19, 2019 | 08:02 AM
JimClementi's Avatar
JimClementi
Is there a guide to taking off the covers? The Bentley manual doesn't cover that.
Old Apr 19, 2019 | 10:49 AM
MVPeters's Avatar
MVPeters
I don't have a convertible, but isn't there a micro-switch under a rear luggage shelf or something?
Old Apr 19, 2019 | 01:25 PM
gum's Avatar
gum
Mines it’s a 2006 convertible base and it does the same thing, what I do is with the Allen key I finished opening the sunroof until I see the light on the switch blinking at that point the convertible should continue to open it.
in my case it doesn’t do it so at that point since it’s unlocked i manually grab the roof a pushed back until it rest in the back of the rear seat if you do that make sure your 1/4 windows are down so you won’t brake them.
what is funny the convertible closes fine without my assistance which I believe it’s the hardest part.
the opening part the gravity helps you.
i was playing with the screw to release the hydraulic pressure to me it doesn’t make a difference.
So i leave I as it is and works fine.
Good luck
i believe that our motor it could be tired because i don’t see anything broken at my end neither or jammed.
Old Apr 20, 2019 | 10:26 AM
sci2000's Avatar
sci2000
I cannot unlock the sliding roof to move it.
Old Apr 20, 2019 | 04:27 PM
gum's Avatar
gum
If you access the motor for the sunroof located at the top between the driver and passenger remove the access cover and with the Allen key help the sunroof to unlocked it, mines take less than one revolution to manually unlock after the sunroof motor stops.
PelicanParts.com
Apr 20, 2017 09:32 AM
gaylon
R57 :: Cabrio Talk (2009+)
23
Sep 11, 2014 03:19 PM
sunsluv
Sep 9, 2013 09:40 AM
not-so-rednwhitecooper
Mar 2, 2009 05:05 AM
DustinDallas
65
Mar 20, 2005 07:14 PM
