R50/53 Pairing the keys
Old Mar 1, 2019 | 05:08 PM
Regis7136's Avatar
Regis7136
Pairing the keys
Hey all. I just replaced the batteries in my remotes because they weren't unlocking/locking my doors. Went the cheap route before buying a new mirror. Both keys start the car but still wont lock or unlock. Anybody have trouble pairing keys after replacing batteries and mirror? Any fixes or is it just try pairing a million times until it works. I've tried about 100 times already with no luck. 06 r50.
Old Mar 1, 2019 | 05:18 PM
Tgriffithjr's Avatar
Tgriffithjr
How did you replace the batteries. I have an 06 and it has the rechargeable batteries that are soldered to the circuit board and sealed inside the key case.
Old Mar 1, 2019 | 05:23 PM
Regis7136's Avatar
Regis7136
You have to cut the key open and desolder the old battery and solder in the new one.
Old Mar 1, 2019 | 06:03 PM
Tgriffithjr
I didn’t realize you had done that. I thought you had keys with non rechargeable batteries the way the post read to me. Try the procedure in this thread, post 11. If you’ve already done this then I’m out of info. Good luck
https://www.northamericanmotoring.co...m-key-fob.html
Old Mar 1, 2019 | 06:07 PM
Regis7136's Avatar
Regis7136
Yes, I've that what feels like a hundred times. No dice. I'm cetainly getting frustrated.
Old Mar 1, 2019 | 06:18 PM
Tgriffithjr
Did you make sure that the switches were still soldered onto the board?
Old Mar 1, 2019 | 06:28 PM
Regis7136's Avatar
Regis7136
I didn't see any broken connections and all the buttons are perfectly clicky. Would desoldering the battery leads cause anything else to desolder. I didn't think it would.
Old Mar 1, 2019 | 06:33 PM
A383Wing's Avatar
A383Wing
I have an '06 R52 and my key fob will not lock or unlock the doors....I also cannot get my Homelink mirror programmed for my garage door opener.....the dealer says my key is fine, they tested it at the service department......I'm thinking my inner rear view mirror circuit board is bad,,,,
I also have tried all the key fob reset procedures that I could find....nothing seems to work
Bryan
Kongfish
Oct 26, 2013 04:06 PM
Kaidaddy
Nov 23, 2011 09:54 AM
pjo1966
Dec 18, 2007 08:19 AM
Drsms22
19
Oct 15, 2007 12:48 PM
BludyL
May 21, 2007 06:53 PM
