R50/53 R53 front bumper leveling
Old Feb 28, 2019 | 03:58 PM
audihere's Avatar
audihere
The driver's side of my front bumper keeps sagging down. I've tightest the screw in the wheel well twice. Anything else I can do to keep it aligned?
Thanks!
Old Feb 28, 2019 | 06:07 PM
Tgriffithjr's Avatar
Tgriffithjr
Hard to say without looking at it. Can you move it up and down after you tightened the bolts. Try and inspect everything.
Old Feb 28, 2019 | 07:45 PM
JAB 67's Avatar
JAB 67
Has the car recently been put in service mode? If so, perhaps the metal bumper beam was not tightened.
Old Mar 2, 2019 | 12:13 PM
audihere's Avatar
audihere
We pushed the driver's side of the bumper up into alignment and tighten up that bolt real good. Everything is very solid for several days, but then I notice is sagging back down again.
Thinking about adding a bigger washer for more grip if there's room next time we look at it.
Old Mar 2, 2019 | 02:06 PM
JAB 67's Avatar
JAB 67
There are two bolts at each corner; one controls the adjustment and the other connects the bumper to the support beam. Are you sure that both are tight? And that the nuts and bolts that hold the support beam in place are tight?
Old Mar 5, 2019 | 11:59 AM
^^+1 Info and DIY here, but these 2 parts there are adjustment 51717039262: https://www.northamericanmotoring.co...alignment.html
Old Mar 22, 2019 | 12:52 PM
audihere's Avatar
audihere
OK, reporting back. After putting a bunch of thought and research into how I was going to get my bumper to stay aligned, I found it was an embarrassingly simple fix. Hood wasn't closing all the way on driver's side. I'd read this as a potential issue on other threads and though, no that can't be it. But sure enough, so easy!
Old Mar 22, 2019 | 01:24 PM
Tgriffithjr
That’s caught me a couple of times also. Must be another defect to put on the list. Surprised none of us thought of it!
Miles30
Dec 17, 2015 11:52 AM
Mjolnir
Oct 29, 2003 04:34 PM
dave
Nov 10, 2002 08:12 PM
