R50/53 keeping busy
keeping busy
My LDS and clutch should be here today, but I'm waiting for my passenger side engine mount to get back from power before I can remove the tranny using the engine support bar from harbor freight. I'm going to replace all the gaskets and O rings too.
These hoses look like they've been soiled a lot and feel flimsy, I'm going to replace them too, does anyone know the part number of them or what they are called? Keep in mind I've never had a R53 previously or taking one apart, they look like part of the heater system. Yes, I'll be replacing the oil filter housing gasket too.
I found the wire that I believe connected to the oil drain plug once upon a time, can anyone confirm if it's a single blue wire lead? I'm sure if this is it I can just add an extension and a female connector to it. I bought the oil plug and it just has a flat male connector attached to it
I also bought a Mishimoto radiator before I read all the bad news about bad welds and leaks. Bummer, hopefully I'll get lucky with this one. Their intercoolers are highly recommended in the diesel world so I figured it would be the same in the MINI world.
I also took the rack off and pump off because I sent my subframe to be powder coated illusion orange.
Those flexible hoses are part of the oil cooler system. Good luck with the Mishimoto radiator; I'm on my third one - the previous two leaked in the same spot and I fear a similar fate for the current one.
where does your Mishimoto leak from?
I may even see if I can return to Way after all the stories I’m hearing and go the Koyo I hear is the go to replacement.
Second... what IS the best radiator out there for the money on an R53... improved or Stock Replacement??
Links and/or prices would be much appreciated!
Where do the stockers typically fail and why?
Looked on realoem.com for part numbers and was surprised to NOT be able to find a diagram of the oil cooler. However, MiniMania sells the coolers/hoses so you might try them.
“I found the wire that I believe connected to the oil drain plug once upon a time, can anyone confirm if it's a single blue wire lead? I'm sure if this is it I can just add an extension and a female connector to it. I bought the oil plug and it just has a flat male connector attached to it.”
Can someone enlighten me about the wire on the oil drain plug? Never heard of that.
@Tgriffithjr - F.Y.I. on the MC40 gauge cluster: https://www.northamericanmotoring.co...gauge-pod.html
I followed the hoses and it looks a little confusing, it goes into a four-way coupling.
R50/53 1-800 ASK-MINI ( Busy)
Smooth is Quik
Jan 3, 2005 10:54 AM
noblecomputing
May 2, 2004 01:24 PM
