2007 Mini Cooper S: Help ID Part
Old Sep 10, 2018 | 07:03 PM
Ctyler15's Avatar
Ctyler15
Can anyone help me identify this part? 2007 mini cooper s. Some sort of sensor on air intake closest to turbo i am assuming. On opposite end of tube from MAF sensor. I have searched everywhere, but unable to locate the sensor plug nor the part the sensor plugs into. What is this called? Thanks for any assistance.
Old Sep 10, 2018 | 10:49 PM
oldbrokenwind's Avatar
oldbrokenwind
The part is a PCV heater. Your last pic looks like the cable that connects it to the ECU. All cable connectors are "keyed" so they should only fit one sensor / fitting, however they can be forced onto the wrong one. A few years ago, I was in a hurry and switched the PCV heater cable with the coolant temp sensor --- blew out the sensor. Use caution when reconnecting cables.
Use this site for an illustrated parts list --- https://www.realoem.com/bmw/enUS/select --- it'll help ID parts you don't know anything about.
Old Sep 12, 2018 | 11:21 AM
+1 ^^ its part of the whole intake hose.
Rubber Boot N14 Engine Cooper S . 13717555784
Linked below here:
https://www.northamericanmotoring.co...id-needed.html
Is the plug on the wire harness side ok?
Old Sep 12, 2018 | 11:32 AM
Ctyler15's Avatar
Ctyler15
The plug is bad as well. Do you happen to have a link for a replacement? Thanks.
Old Sep 12, 2018 | 11:37 AM
Ok, here you go this is the intake hose boot wire harness plug for that N14 engine
https://www.ecstuning.com/b-genuine-...n/12527542852/ 12527542852 x 1
and
https://www.ecstuning.com/b-genuine-...t/12527543260/ 12527543260 x 2
RI!Y]3&aO&2W
May 23, 2023 06:26 AM
ericfreeman
12
May 18, 2017 05:56 PM
Mini-mize-Me
Feb 19, 2013 07:50 AM
01rs25
Aug 25, 2010 09:39 PM
allforknot
12
Mar 18, 2007 10:59 AM
