After Market rally lights
Old Jul 29, 2018 | 08:43 AM
Ace1287's Avatar
Ace1287
Has anyone had any experience with buying/installing after market rally lights such as these from IJDM toy - thinking about rally lights but dont want to pay $450 for OEM
http://store.ijdmtoy.com/MINI-Cooper...wE&click=12691
Old Jul 29, 2018 | 10:06 AM
Capt_bj's Avatar
Capt_bj
I've installed generic kits and factory kits on GEN1 and GEN2
what's the question?
biggest issue is usually the brackets for mounting .... you CAN buy the factory brackets alone from outmotoring .... GEN2 and later cars typically require some cutting esp' of the grill ....
Old Jul 30, 2018 | 01:56 PM
Subw00er's Avatar
Subw00er
The Piaa in my sig are good. I used some ebay mounts and one of them bounces a tiny bit because its not resting on the grill (you have to slot the jcw grill to fit them).
Old Jul 30, 2018 | 02:12 PM
BluGnat's Avatar
BluGnat
I've got KCs on mine. Mounting brackets are from MiniMania. My husband also put a 10" KC light bar in the grille of his JCW.
Old Jul 30, 2018 | 02:26 PM
MVPeters's Avatar
MVPeters
2 x Hella500 from any auto store, wiring kit & relay may come with them. Brackets from any of the vendors on here. All for about $100.
(3W LEDs are about as bright as a flashlight & about as much use).
Old Jul 30, 2018 | 03:55 PM
S-2013's Avatar
S-2013
Yes, I have experience with these having replaced the OEM rally lights with them. I just removed and replaced them utilizing the existing mounts. Quality is just as good as OEM and the light output far exceeds stock with the added benefit of bright DRL halos. Only had to run an additional wire for switched power to operate the DRL’s.
Old Aug 2, 2018 | 11:22 AM
bratling's Avatar
bratling
Super Moderator
Does anyone make inexpensive mounting brackets? All the major vendors I know of – Outmotoring, MiniMania, Craven – charge a lot. (Which is understandable, because it's a specialized product for a small market, so they have to charge a lot to recoup the time invested into creating the products. But that doesn't make it any less painful to me as a buyer. It hurts to spend $200 for mounts for $20 lights.)
Old Aug 2, 2018 | 02:59 PM
Capt_bj's Avatar
Capt_bj
know a friend who can work with metal?
I can make a set for around $10 ... but that is because I have a significant investment in tools and equipment ......
Old Aug 4, 2018 | 09:24 AM
bratling's Avatar
bratling
Super Moderator
i should have guessed my metal working skills and tools are limited to bits of lightweight, Home Depot grade aluminum.
Old Aug 4, 2018 | 03:23 PM
ammodave's Avatar
ammodave
A hammer, hacksaw, a couple of files, a drill, and a bench vise will get you there. I made mine out of 1/8" steel. See my gallery for photos. I did not modify the grill.
Old Aug 6, 2018 | 09:16 AM
CravenSpeed's Avatar
CravenSpeed
Vendor
For anyone looking for an off the shelf, non-universal, made in good ol' USA solution, we've got you covered!
CravenSpeed Auxiliary Light Mounts
These should be going into production very soon, and I should have them available on the site in the next month or two. Will be sure to let you guys know here.
-Logan
Old Aug 6, 2018 | 01:04 PM
bratling's Avatar
bratling
Super Moderator
Originally Posted by CravenSpeed
For anyone looking for an off the shelf, non-universal, made in good ol' USA solution, we've got you covered! […]
Please do!
Old Aug 6, 2018 | 01:15 PM
Capt_bj's Avatar
Capt_bj
price?
I agree .... I have some fancier tools that get me there faster but you can do a good job with the above. Home Despots or Lowes or ACE has steel stock .... you can make a good set of brackets with some 1/8 thick 1/2 wide flat stock. A 3 foot piece is just a few dollars in alum', mild steel or stainless. The most important tool is probably the vise to hold the metal while you bend it (working like a bending brake tool https://www.eastwood.com/metal-fabri...tal-brake.html ) cut it and drill it.
The hard part is figuring out where & how to mount the bracket .... design the thing in other words. The actual bending and cutting of the metal is usually the easier part! Having a person who's bent some metal b4 helps .. but there's a first time for everyone . .
p.s. I found ammodave's gallery (they are kind of buried on the site now) .... I'm not a big fan of attaching the brackets to the grill ... the grill is plastic which gets brittle with age and I'd be concerned with the weight of the lights. OTOH the new LED lights may be lighter so ...... but IMO the bracket is best mounted to a "hard point"
Old Apr 30, 2024 | 05:54 PM
modgeezer's Avatar
modgeezer
ijdmtoy rally lights on R56 2013
Bought the Ijdmtoy led rally lights. They are supposed to have a ring when you turn on daytime driving lights and the inner circle should light up when the headlights are turned on. When i attach the red wire to the 12v connector in the fuse box the ring turns on and stays on wether the key is in the car or not they never turn off. when i switch the driving lights to the on position the inner lights turn on. Does anyone know what im doing wrong or where i should just splice the wires to get these to be off when the car is off, ring in daytime mode and inner circle with headlights turned on. attached is a picture of the wiring harness included. It plugs into the original driving lights than the drl connect to the new harness. then the harness connects to the two rally lights and the red wire is connected to the 12v in the fuse box
included harness
Reid Hauenstein
Jan 15, 2020 11:10 AM
six-fingers
Jan 19, 2013 09:40 AM
Daiseyhead R55
R55 :: Clubman Talk (2008+)
Nov 6, 2011 03:03 PM
benzoc
Mar 29, 2010 02:54 PM
OKMini
Nov 28, 2003 01:21 PM
