2008 Cooper S PCV hose replaced with heater hose—hose collapsing?
Old Jul 27, 2018 | 04:59 PM
jimmwaller's Avatar
jimmwaller
Hello,
I've been trying to track down some mysterious air leak issues in my 2008 Mini Cooper S turbo. One of the things I saw recommended here a few times was to replace that crappy brittle plastic PCV hose with rubber heater hose to eliminate any air leaks from the PCV.
Well, I did that, and I actually found it to be... almost worse. The stock hose is rigid, and probably for a reason: The bends all fit where they are supposed to go and fit around corners and stuff. My hose kept kinking, and blocking off the PCV entirely. Eventually, I found a way to get it to loop properly and leave the hose open.
Now, I'm having major idling problems, and I recently realized that what is happening is that as the engine runs, the vacuum generated in the PCV hose is enough to collapse the heater hose and cut off most of the flow. The rigid plastic hose wouldn't collapse, but the heater hose is weaker
Am I just doing something wrong? Has anyone actually ever done this mod successfully? Or is it somehow fine that it's collapsing?
Any insights would be appreciated.
Thanks!
Old Jul 27, 2018 | 05:50 PM
downshift1's Avatar
downshift1
Also heater hose is not oil resistant so it will break down quickly. I would order a factory replacement hose.
Old Jul 27, 2018 | 07:06 PM
jimmwaller's Avatar
jimmwaller
....oh. Thanks for the reply. So this "recommended" fix isn't really very a good idea... shoot.
Well, good to know for future people who stumble upon this thread!
thanks
Old Jul 27, 2018 | 11:35 PM
drea-min's Avatar
drea-min
Vacuum hose
when i install Oil Catch Can i used vacuum hose made with Silicone 3/4” i cut off both end because the ability to quickly disconnect the hose, it kink a little but not enough to restrict the fllow that cause a rough idle, if it wasn’t for the OCC i wouldn’t replace with other hose i’d recommend the stock hose and they fairly cheap at GeekParts.com
i tried to used radiator hose and even the black hose for the washing machine but both collapse and i didn’t like it. Good luck
Old Jul 28, 2018 | 07:47 AM
downshift1's Avatar
downshift1
Silicone hose is also not oil resistant.
If you have a Industrial / hydraulic hose shop stop by and explain what you're attempting to do and they have a better option for you if you're set on not buying the OEM part.
Old Jul 29, 2018 | 03:23 AM
mustangcruise's Avatar
mustangcruise
When I installed my OCC I went to NAPA and picked up some Gas/Emission hose. Fairly inexpensive and had no issues.
Old Nov 15, 2019 | 01:47 PM
Lex2008's Avatar
Lex2008
I have a new motor on my 2008 cooper s and i found the oem pcv house collapsed. The hose is original with 156k miles.
Anyone find a proper repair? Has the part been revised by mini?
Old Nov 15, 2019 | 02:17 PM
Wow never really seen one collapse like that. I can see it was updated with a newer part number: 11157565449 was the older part number which update in 2011.
https://www.ecstuning.com/Search/Sit...h/11157605186/
Old Nov 15, 2019 | 05:45 PM
Lex2008's Avatar
Lex2008
Thanks Mr. ECS Tuning. Appreciate it.
Old Nov 16, 2019 | 02:34 PM
Lex2008's Avatar
Lex2008
Totally collapsed OEM PCV hose on 2008 R56 Cooper S
Old Jan 16, 2022 | 09:01 PM
BCakes504's Avatar
BCakes504
Thanks this most definitely helped me.
thanks
Minmcint
Mar 2, 2019 07:12 AM
frank miller
20
Jun 4, 2006 06:16 PM
moreorless
Sep 4, 2005 08:05 AM
dominicminicoopers
May 14, 2004 09:47 AM
miniwanna
Jul 26, 2003 09:53 AM
