R56 2013 R56S oil pressure sensor wiring
Old Jul 16, 2018 | 08:13 PM
Gambedegallina's Avatar
Gambedegallina
Long story...need to know which color wire connects to which color wire on either side of connecting harness for OP sensor. Anyone know or have access to wiring diagram with wire colors indicated.
Thanks!
Old Jul 16, 2018 | 09:16 PM
cornjuice's Avatar
cornjuice
news to me.. N18 only??
*R56 w/ OP sensor.. what? sub'd for more details
Old Jul 17, 2018 | 05:54 AM
MiniToBe's Avatar
MiniToBe
here you go
https://www.newtis.info/tisv2/a/en/r...ntrol/CkYCzqZ9
if you look inside the plug, you will see the numbers or at least no.1 pin notated.
Old Jul 17, 2018 | 07:05 AM
Gambedegallina
Thanks. This may help. Wires on one side of connector came out. Colors of the 3 wires on either side of connector do not match, so trying to avoid RE-assembly guess work.
Old Jul 17, 2018 | 07:15 AM
MiniToBe's Avatar
MiniToBe
post a picture if anything.
Old Jul 18, 2018 | 11:30 AM
Tigger2011's Avatar
Tigger2011
Alliance Member
Need the last seven of the vin to tell you colors as they vary.
Old Jul 18, 2018 | 01:38 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
N16 Non-S
2013 N18 S-Model
Old Aug 24, 2018 | 10:45 PM
Gambedegallina
Thanks to all. Problem solved.
Old Nov 23, 2019 | 08:31 AM
wascobi's Avatar
wascobi
oil pressure sensor wiring colours
so my three wires are different colours than the diagrams in this thread. I have a 2013.3 N16. there is a green and a black twisted together, and a white. my hope is that I can figure out how to use the three-wire sensor in the oil filter housing of my new N16, in my single-wire 2007 that had the head mounted sensor. or find a single-wire sensor that fits the oil filter sensor hole.
Old Nov 24, 2019 | 04:09 AM
MiniToBe's Avatar
MiniToBe
You can a actually remove the plug on the N16 head and place the old oil pressure sensor. Leave the new on in place.
Old Nov 26, 2019 | 05:33 PM
2013coopy's Avatar
2013coopy
Oil pressure solenoid
Originally Posted by MiniToBe
here you go
Hello I have a question regarding this thread, is the oil pressure valve the same as the oil pressure solenoid and where is located? I will appreciate any help I am getting this code 33fd meaning that the oil pressure is high and 3405 .
Old Nov 27, 2019 | 03:24 AM
MiniToBe's Avatar
MiniToBe
Oil pressure valve is the sensor on the oil filter housing. The solenoid is the one attached to the oil pump. Read live data of the oil sensor to see what the numbers are and if they make sense.
Old Nov 27, 2019 | 04:45 PM
2013coopy's Avatar
2013coopy
Thank you for making things clear, I am working in getting the parts and
put this baby back to normal condition, thank you again.
VisualMemoryUnit
Feb 3, 2021 10:23 PM
Bodacious
Jul 9, 2018 07:04 PM
victor247
Jul 22, 2014 07:26 PM
K9Projectworks
Sep 12, 2011 07:01 AM
crackerjack
May 10, 2009 07:20 AM
