Drivetrain over boost issues 07 cooper s with mods
Old Jul 8, 2018 | 05:33 PM
E34M5's Avatar
E34M5
What controls boost pressure on 07 S? installed jcw turbo, accessport tune, upgraded exhaust, intercooler, alta recirc valve, silicone turbo pipes. over boost occurring under 4,000 rpm, boost pegs 24 psi then over boost kicks in cuts boost and power. what sensor inputs could affect his, also what controls boost pressure? is it all electronically controlled through ME?
Old Jul 9, 2018 | 02:52 PM
freestylin599's Avatar
freestylin599
Not sure its probably the electronic boost controller but they sometimes have this issue you need a boost valve to fix it. you needs this i have one works great
http://boostvalve.com/mini-1.6l-turbo-fix.html
Old Jul 16, 2018 | 11:45 AM
oldbrokenwind's Avatar
oldbrokenwind
If the wastegate never opens, boost will build continually. Have you checked the WG system operation?
Old Jul 16, 2018 | 05:50 PM
E34M5's Avatar
E34M5
Yes figured out the problem the wastegate linkage was binding. Thanks
Freedirt
Aug 18, 2018 09:07 AM
sushiman808
Jul 3, 2018 08:32 PM
Bossworld
Jun 27, 2018 05:33 AM
eschantra
Jun 22, 2018 04:22 AM
Spectre125
Jun 19, 2018 10:58 PM
