Navigation & Audio R58 speaker upgrades for a start
Old Apr 8, 2018 | 04:31 PM
mpm's Avatar
mpm
Finally started my upgrades. My car is a 2012 Coupe S R58. I'm not a brand name person so no Pioneer or Kenwood for me. I decide on what specs are important to me and I buy raw speakers. For this install I'm going with PRV from Parts Expresss. Install was pretty straight forward with only a few mild modifications needed. I have only installed them in the passenger door so far.
I'm gonig to let them break in for a week or so and then compare them to the still installed factory speakers on the drivers side. My R58 came with the base model stereo so no tweeters like the Harmon Kardon setups. Initial impression is an improvement in clarity especially on the high end. Bottom end is there but still nothing to write home about. I have not done the harness swap so the front speakers still get a full range signal. My final install will have a custom 2nd order 3-way crossover with a tweeter install somewhere in the usual spots. I like designing my own crossovers and there is plenty of room in the armrest.
Future plans include the usual headunit, amp and woofer.
https://www.parts-express.com/prv-au...-ohm--294-2703
https://www.parts-express.com/prv-au...-ohm--294-2760
Old Apr 10, 2018 | 06:58 AM
I have the HK and it sounds great. I dont know why people opted for the base system. There used to be a factory Alpine system that was made for the MINI, but its NLA now.
Looks good so far and are you adding a tweeter? When you do you could just get the factory A-pillars with the tweeter pods, then swap in the aftermarket ones.
Old Apr 10, 2018 | 10:42 AM
mpm's Avatar
mpm
Would have been nice to have the HK system to start with. I wouldn't be going thru this upgrade. But it's fun for me especially if the outcome is good.
I will be adding a tweeter. I though about the A-pillars but for the cost of new A-pillars I can get a good 4 channel amp. Will likely add the tweeters to the top of the door. But I am going to do some placement testing before making a final decision. I have the tweeter linked below. It sounds good but is a little more difficult to mount and have it look factory. When I get closer to finalizing this I'll try it everywhere. Reflecting toward the windshield from the dash, mounted on the windshield both high and low next to the A-pillar, on the door panel, etc.....
https://www.parts-express.com/dayton...6-ohm--275-083
I may still end up with a traditional dome tweeter but I really like the planar.
Old Apr 12, 2018 | 05:50 PM
mpm's Avatar
mpm
https://www.parts-express.com/tang-b...4-ohm--264-845
Another possible tweeter option. This one will mount nicely with the aluminum body and ring. Good specs and you can cross it over pretty low. I may be ordering myself a set of these.
Str8Grizzly
Mar 14, 2013 06:01 PM
ericmakkar
May 20, 2011 05:16 PM
Guest
Sep 21, 2007 08:41 PM
DjR53
16
Apr 27, 2007 07:25 AM
mingus
Oct 6, 2006 12:58 AM
