F55/F56 Coding parameters that actually work using Bimmercode Expert Mode
Old Sep 17, 2017 | 06:02 PM
TVPostSound's Avatar
TVPostSound
Coding I tested today using Bimmercode Expert Mode:
Add as you wish, but only tested and working functions.
Activate Rear Fog Lights:
3068 NSL_Verbaut = Verbaut
Code first, the cycle ignition, then restart Bimmercode for the below options
to show up
Activate Rear Fog Lights feature for lighting switch:
3064 Mapping_Nebelschlussl_L_output = nsl_l
3064 Mapping_Nebelschlussl_L_Function = nebelschlusslicht
3064 Mapping_Nebelschlussl_R_output = nsl_r
3064 Mapping_Nebelschlussl_R_Function = Nebelschlusslicht
Every time you recode after doing rear fogs, you WILL get a dash warning about lighting errors.
cycle the ignition, it will go away, the warning after coding is because the VO has not been coded.
It will not persist after that.
Close windows, sunroof & mirror from key fob:
3056 KOMFORTSCHLIESSUNG_FB = aktiv 00
Turn off window roll-up door interrupt when ignition off, and door is being opened:
3050 FH_TUERAUF_STOP_MAUT =aktiv
Disable Active Sound Design
3000 ASD_SOUND_OFF = aktiv
Display Tire Pressure & Temperaure in Vehicle Info:
3001 RDC_SAFETY = aktiv
Fogs on with high beams
3068 NSW_AUS_BEI_FL = nicht aktiv (AUS means off + nicht aktiv is a double negative = ON, so nicht aktiv)
Fogs on with DRL/Parking lamps
3068 NSW_EIN_AUF_LDS_STL =Activ (EIN_ AUF means To go on)
Enable Illumination of Exterior Door Handle LEDs when in Reverse
3070 OVT_BEI_REUCKFAHRLICHT = aktiv
Installed LED reverse lights:
Turn off warm and cold monitoring
Turn on LED status
Rückfahrscheinwerfer = Reverse lamps. RFS
3061 RFS_L_KALTUEBERWACHUNG = nicht aktiv
3061 RFS_L_WARMUEBERWACHUNG = nicht aktiv
3061 RFS_L_IS_LED = aktiv
3061 RFS_L_IS_LED aktiv
Tip blinker stalk for 5 blinks instead of 3.
3069 PIA_DEFAULT_TIPPBLINKEN =FUENFMAL
Old Sep 17, 2017 | 06:44 PM
vetsvette's Avatar
vetsvette
Moderator
Have you tried enabling foglights with high beams?
Old Sep 17, 2017 | 07:14 PM
TVPostSound
BDC Module
3068 NSW_AUS_BEI_FL nicht aktiv
It translates to fog lights OFF with high beams (default is aktiv)
So you double negative the response to leave on.
But it won't do what the R56 did after coding which is turn off fog during high beam pull to pass.
I miss that. So it would look like youre flashing the high beam alternating with the fog when doing an Autobahn
flash.
Old Sep 18, 2017 | 05:57 AM
trentiles's Avatar
trentiles
Have you tried the coding so that the "mode", sport, normal, green is retained when you turn off/on the car?
Old Sep 23, 2017 | 05:26 PM
TVPostSound
So looking at Brake force display.
The options are blinkend meaning blinking at hard braking over 43mph
The factory default set on mine is flächenvergrößerung meaning increased area.
What? Do my brake lights get brighter on panic stops??
Old Sep 25, 2017 | 04:23 PM
Kazmini's Avatar
Kazmini
...someone give me a step by step on what I need to do to do the above please!
Old Sep 25, 2017 | 05:50 PM
vetsvette's Avatar
vetsvette
Moderator
Finally picked up my iCar dongle. Supposed to cool off this weekend so I'll probably start fiddling with the app then, both basic and expert. Seems TVPS has already listed just about everything I need for the expert part.
Old Sep 25, 2017 | 07:34 PM
TVPostSound
This version of Bimmercode is missing a bunch of settings as compared to the website.
Those settings are basically scripts or shortcuts pointing to expert mode.
Expert mode scans all the modules, so everything that can be done
with ESys and a laptop can be done with Bimmercode.
The only things that can not be done is VO additions, GPS maps and
Sirius XM coding.
Old Sep 25, 2017 | 07:36 PM
TVPostSound
You're probably in your driveway as we speak, coding away.
Old Sep 25, 2017 | 08:28 PM
TVPostSound
You,sir have a 2012?
Read here
https://www.northamericanmotoring.co...-yourself.html
Old Sep 26, 2017 | 07:48 PM
TVPostSound
Added
3070 OVT_BEI_REUCKFAHRLICHT =aktiv
Old Sep 26, 2017 | 09:34 PM
vetsvette's Avatar
vetsvette
Moderator
I thought that was available in the basic app.
Old Sep 27, 2017 | 02:53 PM
TVPostSound
See Post #8
Old Sep 27, 2017 | 05:25 PM
TVPostSound
Bimmercode just came out with an update, maybe its fixed.
Ill check
EDIT: Yes, he fixed a few shortcuts.
Old Oct 1, 2017 | 01:10 AM
johntotah94's Avatar
johntotah94
Anyone get the //M Laptimer to work? It connects for a second to my iPhone app then disconnects.
Old Oct 1, 2017 | 07:09 AM
Scooter24's Avatar
Scooter24
Just curious on the tire pressure and temp display. I have a 2011 mcs that had the boosted CD Harmon kardon system in it. I retrofitted oem nav and mini connect in the car and when I go into vehicle info it shows the the car and that tire pressure is "ok" so if coded it should show the pressure and temp?
Old Oct 1, 2017 | 10:41 AM
TVPostSound
Wrong thread, this is for F series, not R
R series did not report tire pressures.
Old Oct 11, 2017 | 08:30 PM
TVPostSound
Installed Osram 7556 LED Reverse Lamps
Left is OEM, right is LED
Coding is on the original post above:
Old Oct 16, 2017 | 06:24 AM
trentiles's Avatar
trentiles
Just got Bimmercode and the wifi adapter.
Seems like I am having some luck with certain changes, but not others.
One that doesn't work is setting lane change indicators from 3 to 5. It just always blinks 3 times. Has anyone gotten this to work?
Also one strange thing, when I got into the ASD menu and then Export - Model it says my model is F022 and not F055 like I have. Can someone verify this setting on their car? I was a bit hesitant to change it to F55 even though that is the model I have.
Old Oct 16, 2017 | 06:32 AM
TVPostSound
I’ll check tonight
Old Oct 16, 2017 | 11:16 AM
trentiles's Avatar
trentiles
Answering my own question - it was set to F022 due to coding ASD off using Carly. Changing the model is a way to turn off ASD.
I changed the model back to F055 but it seems like ASD is still off, I am trying to get it back on.
Going to see if I can do a restore of the ASD module using Carly backup and see if that fixes things.
Old Oct 16, 2017 | 12:25 PM
TVPostSound
Yeah, if you notice, in Bimmercode, he noted to restore backup to revert.
I also don't think there are more than on "sound" for our cars. I tried an M4, and nothing.
Old Oct 16, 2017 | 03:38 PM
trentiles's Avatar
trentiles
Have you tried the 5 blink indicator setting? Any luck?
Old Oct 16, 2017 | 05:42 PM
TVPostSound
Haven't tried it.
If your having issues with the shortcuts, you'll need to go into expert mode.
I had problems with the brake lights switching to LED, until I did it in expert mode.
Old Oct 16, 2017 | 08:33 PM
TVPostSound
Try
3060 Blinkzyklen_anzahl_tipp
Custom value= 0x04
einmal 0x00=Once
dreimal 0x02=Thrice
Max is 0x07
