F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Bimmercode app
Old Sep 10, 2017 | 07:49 AM
BazV's Avatar
BazV
Bimmercode app
Hi guys. Have anyone used the bimmercode app? Ive seen the carly app, its good but the bimmercode seems better for easier coding, but has anyone used it?
Old Sep 11, 2017 | 12:39 AM
Nimrandir's Avatar
Nimrandir
I should receive the wifi adapter today and i will give it a try...
Beside being cheaper than Carly's app it appears to have more potential with the "Advanced mode" that is very similar to the options you have while coding with the "professional tools" on the pc
I will let you know how it goes...
Old Sep 11, 2017 | 06:45 AM
pw1114's Avatar
pw1114
Bimmercode is worlds better than Carly.
Both can do all the normal basic coding options like rear DRLs, comfort closing, etc.
With bimmercode, I was also able to add rear fogs, and upgrade my display from 6.5" visual boost to 8.8" visual boost (no nav), among other things I can't think of right now. This is thanks to the expert mode it has.
Old Sep 11, 2017 | 08:54 AM
TVPostSound's Avatar
TVPostSound
What did that do for you??
I have 6.5" with no nav too!
Old Sep 11, 2017 | 09:13 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
I seem to recall reading on the BMW forums that Bimmercode was good but that once you coded an option you couldn't go back and undo it. Is that the case, or was it bs?
Old Sep 11, 2017 | 11:20 AM
pw1114's Avatar
pw1114
Its only visual difference, so you get the tiered style menus, which I guess is more convenient since you can see more information all at once. But mostly, I wanted it because I wanted to be able to see album art, album name, and track title all at the same time while playing music. Plus it was just a project I wanted to do.
pw1114's Avatar
pw1114
It was bs.
Old Sep 11, 2017 | 04:08 PM
Minnie.the.Moocher
It was bs.
Do you need the adapter they mention on website or will other OBD ones work? I already have a few of them.
Old Sep 11, 2017 | 04:48 PM
pw1114's Avatar
pw1114
Haven't tried any other ones except the one they state is needed, so I can't make any assumptions.
Old Sep 11, 2017 | 08:17 PM
TVPostSound
Bimmercode saves backups, first backup upon reading.
Old Sep 11, 2017 | 08:24 PM
TVPostSound
I tried the Black and yellow one I used for Dash Command, didn't work, had to buy the recommended one.
Old Sep 11, 2017 | 08:41 PM
vetsvette's Avatar
vetsvette
Moderator
So, how does it work? Do you have a link to the app?
EDIT: Downloaded the app. Just have to order the interface now.
Old Sep 13, 2017 | 08:17 AM
zagman's Avatar
zagman
Have anyone compared the list of coding actions between Carly and Bimmercode? I have Carly but I am not thrilled with it.
Old Sep 13, 2017 | 08:51 AM
TVPostSound
Make sure, on Amazon, you click the correct one when choosing the pretty colors.
Some are IOS, and Android, others are Android and PC. Be careful.
Thats maybe why a few bad reviews about not working correctly, wrong one picked.
Old Sep 13, 2017 | 05:14 PM
vetsvette's Avatar
vetsvette
Moderator
Yep. already checked that out. I could never get Carly to work on my car. Amazon refunded the Carly adaptor, but I had to eat the cost of the app. At least everything seems to be less expensive on the Bimmercode setup and it seems to offer more options too.
Old Sep 15, 2017 | 03:39 PM
BazV's Avatar
BazV
I bought the app and the recommended wifi adapter, it works flawless.
Is there a list of coding parameters for the expert mode?
Old Sep 16, 2017 | 02:54 PM
vetsvette's Avatar
vetsvette
Moderator
Just ordered my interface. I have the basic app downloaded and of course all I can do is play with the demo. I'm curious also if there is a list somewhere so I can decide what changes I want to make while waiting for delivery. What is the cost of the actual app? Is there a basic and expert mode? And if so, what's the fee and/or advantages of the expert mode?
Old Sep 16, 2017 | 06:18 PM
TVPostSound
Make sure you have today's update. It has been updated to work with the latest MINI reprogram.
If you ordered your interface from Amazon,
make sure the seller is "ediag tools", not "UCar Technology CO.,ltd"
It seems the latter has more failure rates, and I can't prove it, but me thinks they resell the failed ones.
Look at the feedback.
Old Sep 16, 2017 | 06:25 PM
TVPostSound
Expert mode, for instance, allows you to add rear fogs, by adding the switch and adding the lights using the same language as E-SYS
(Add rear fog/ activate rear fog switch)
3068, NSL_Verbaut = Verbaut
(Map the switch to lamps)
3064 Mapping_Nebelschlussl_L_output = nsl_l
3064 Mapping_Nebelschlussl_L_Function = nebelschlusslicht
3064 Mapping_Nebelschlussl_R_output = nsl_r
3064 Mapping_Nebelschlussl_R_Function = nebelschlusslicht
The basic menu is just that, basic on and off stuff.
Old Sep 16, 2017 | 07:32 PM
vetsvette's Avatar
vetsvette
Moderator
I ordered the one from edlag because the reviews were so much better than the alternative offering. Supposed to be here Tuesday.
Old Sep 16, 2017 | 08:55 PM
BazV's Avatar
BazV
The app is basic on and off so very easy to use until you choose the expert mode, then its all in german and a lot of features you fan code, if you know whats what.
Ive been looking at this for a while. http://www.bmwesys.com/guides/. Check it out, hopefully something there for everyone.
Old Sep 16, 2017 | 09:43 PM
TVPostSound
That sheet is no very correct, and not up to date.
E:G:
It shows 3063 for rear fogs, when it should be 3064
Also routes both l and r signals to l
Old Sep 16, 2017 | 09:44 PM
TVPostSound
Good!!
The one I had from UCar died, the replacement Ediag one arrives Wednesday.
Amazon returns are the best!!
Old Sep 17, 2017 | 01:19 AM
BazV's Avatar
BazV
E:G:
Where can i get an upto date list from?
Old Sep 17, 2017 | 02:27 PM
TVPostSound
Anyone use the latest Bimmercode?
Comfort Closing Keyfob, Window up with ignition off, start without brake pedal, or clutch.
Gone??
Is it me, or Bimmercode?
Oh Well, it moot, I can do it in expert mode
