2014 Countryman S Xenon Bulb Removal and Replacement
Old Oct 15, 2016 | 06:58 PM
geometrix's Avatar
geometrix
Hey Everybody,
I have a 2014 Countryman S. A warning light turned on this evening just as my right headlight started flickering. I am assuming that the bulb is "bad" and that it needs to be removed and replaced.
I did the typical Google searching etc. I see how to remove the plastic cover on the headlight housing, but I cannot figure out how to remove this bulb. Do I turn it? Pull it??????? How do I get this thing out????
Please see the attached photos. I believe that my Countryman S has the Xenon bulbs because I see PHILIPS XenStart on the back of the bulb...or is this the starter?
Do the bulbs come separate from the starters? Or are the bulbs integrated into the starters where the bulb and starter come in one piece?
Can I purchase these parts at Autozone? Or do I need to go to a MINI dealership?
Thanks in Advance,
Neal
Attached Thumbnails 2014 Countryman S Xenon Bulb Removal and Replacement-img_7669.jpg   2014 Countryman S Xenon Bulb Removal and Replacement-img_7670.jpg   2014 Countryman S Xenon Bulb Removal and Replacement-img_7673.jpg
Old Dec 3, 2016 | 04:50 PM
rishardh's Avatar
rishardh
I just replaced mine today. The connector plug was at the 6 o-clock position and using that a reference I twisted the square assembly clock wise to the 7 0-clock position and pulled it out. Once out, unplug the connector.
Could not put it back doing it in reverse. Twisting from 7 o-clock to 6 o-clock anti clock wise did not work. What worked was putting it back in the 5 o-clock position and going clock wise to the 6 o-clock position.
FYI, one replacement bulb was $108 at pep boys (Phillips) and I got a pair for $26 from Amazon (Unknow Brand). Search for D1S 35W Xenon HID. I do not know how long they will last but at that price I will give it a try.
Old Oct 26, 2017 | 11:57 AM
bmaillard's Avatar
bmaillard
Thank you!
Thanks rishardh! I have been looking all over YouTube and the web to find out how to get those darn bulbs out! I searched for MINI Countryman R60 HID Xenon bulb replacement a thousand different ways, and only ever found other MINI models (which are different!) It turns out that all I had to do was turn the damn bulb with a little more force! I was just afraid I was going to break it. On other models there are little spring clips, so I thought maybe I just wasn't seeing them!
This helped immensely! I didn't want to pay the dealer $400 bucks to do a 2-minute job that I could do myself!!!
FWIW, I have a 2013 MINI Cooper Countryman S All-4 with HID Xenon headlights. Once I knew how to get the bulb out, it was a cinch to replace! Incidentally, I used the Philips bulb that is an *exact* replacement for the stock OEM bulbs:
Amazon Amazon
It's a Philips D1S C1, 85V, 35W bulb, had on Amazon for $60bucks each!
Old Mar 1, 2018 | 06:23 PM
kgelner's Avatar
kgelner
Thought Osram was supplier...
Originally Posted by bmaillard
Incidentally, I used the Philips bulb that is an *exact* replacement for the stock OEM bulbs: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Thanks also for the description, one of my bulbs just went out so this is handy material.
I was looking at some other sire, and it claimed Osram was the current bulb supplier though - maybe it's changed? They seem to have a somewhat better rating, and are a little cheaper. I looked at the Osram bulbs on Amazon and found they were cheaper there, but some reviews said they were not getting working units or real Osram bulbs, so I ended up ordering from the other site I found:
https://www.pelicanparts.com/catalog...ELLITE_pg1.htm
Old Mar 11, 2018 | 02:57 PM
kgelner's Avatar
kgelner
Changed bulbs, slightly different.
As a followup, I just changed my bulbs - the bulbs from this site did come in boxes and looked legit (as much as anything can these days).
The bulb changing process was really easy but slightly different than others described - I have a Countryman ALl4 S (R60) with ~110k miles on it.
The rear cover on the headlights came off easily on both sides, then I found to get both bulbs out I had to turn them just 1/8 of a turn or so to the left, counter-clockwise (looking at the back of the bulb). To get the new bulbs in it was exactly the reverse, put them in about 1/8 turn to the left, then turn them back in place until they lock and are straight. I didn't have to use much force at all to either get them out or to put the new bulbs back in. The cable also unplugged fairly easily and plugged into the new bulbs just fine, I didn't verify it could only plug in one way but it's pretty obvious how it all goes.
I wore some thick rubber gloves but other than that precaution the change was very easy, I think pretty much anyone could manage changing these.
As a side note, the gasket for the cover on the side of the bulb that went out looked not as good as the gasket on the side that was still working, so I'll probably replace both gaskets too. It may be worth examining those every four years or so as it's really easy to just pop off the cover and take a look (no gloves required there, all plastic).
Old Dec 16, 2025 | 05:40 AM
voicekiller's Avatar
voicekiller
Wondering if anyone has seen this discrepancy. I went to change my Xenon bulbs and while the Philips site says D1S C1 35w is the correct bulb for the 2014 Countryman, when I went to remove my bulbs, it shows D5S 25w.
Has anyone run into this? Which bulb did you end up installing?
the
Old Dec 16, 2025 | 07:02 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The factory supplied xenon headlights used the D1S bulbs, the dealer installed accessory xenon headlights utilized the D5S bulbs. Looks like your car has the dealer accessory headlights.
Old Dec 16, 2025 | 07:15 AM
voicekiller
Wow. Thanks internet! I never would have figured that out on my own. I called both Philips and the dealership and they said to get the D1S.
So follow-up, are they interchangeable in this case? Can I use the D1S or do I need the D5S?
Old Dec 16, 2025 | 08:34 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Unfortunately, they are not interchangeable.
Old Dec 16, 2025 | 09:06 AM
voicekiller
Sorry, one more follow-up. I tried calling Philips to confirm the correct model and they're insisting the 14002-11 is a halogen bulb!? That's got me very confused. They sure don't look like halogens and I thought I bought the Xenon.
Any chance you could send me a link to what you think is the correct bulb?
Old Dec 19, 2025 | 08:49 AM
Yep its the old kit thats NLA its 25W VS 35W
https://www.northamericanmotoring.co...r-r60-r62.html
https://www.ecstuning.com/News/MINI_...012_2013_2014/
ECS News - MINI R60/R61 Genuine Xenon Headlight Kit
Options for bulbs/ignitor.
https://www.ecstuning.com/b-morimoto...500k/b960~mor/
https://www.ecstuning.com/b-morimoto...500k/b970~mor/
https://www.ecstuning.com/Search/Sit...h/63102348891/
The Genuine MINI ones jumped down in price.
Removal is like the ones on the Chevy side and audi side. https://www.dieselplace.com/threads/...emoval.934618/
8V Facelift, replacing D5S Xenon bulb - Audi A3 (8V) Forum - Audi Owners  Club (UK)
Old Dec 20, 2025 | 09:17 AM
voicekiller
Thanks @ECS Tuning! This is exactly the info I need.
Old Dec 22, 2025 | 10:00 AM
Glad to help!
Old Dec 26, 2025 | 12:43 PM
Where you able to get them fixed?
Old Dec 26, 2025 | 03:10 PM
voicekiller
Sort of. Ordered a set from you. Just waiting for you to come back from Christmas to ship them. ;-)
Thanks again.
Old Feb 3, 2026 | 10:57 AM
voicekiller
Quick update for others.
ECS wasn't able to get stock of the OEM bulb. Morimoto said their bulbs 'may not work in automatic mode because there is a difference in amps. The ballast and igniter are integrated into one unit which requires a stable and consistent power source.' So, decided not to try theirs.
No luck ordering Philips D5S bulbs from Amazon.
So I've got an Osram bulb on order from LEDPerf. I'll post an update once received on how they work out.
https://www.ledperf.ca/xenon-bulb-d5...-p-109616.html
Old Feb 3, 2026 | 11:09 AM
Yep sorry MINI just nla the bulb. :( We have flosser but its more money. D5S is an odd bulb.
Old Feb 3, 2026 | 11:59 AM
voicekiller
All good. I'd still be lost if you hadn't replied in the first place! I should have taken another look at the Flosser.
Update was more for thread, so others have solutions.
C
Old Feb 3, 2026 | 12:44 PM
Yep no problem
ZigsB53
Nov 27, 2011 01:36 PM
resipsamcs
Electrical
Oct 9, 2010 09:36 PM
dj.papazian
Dec 29, 2009 10:27 AM
donjulio
May 14, 2008 07:38 PM
Daytona955i
Mar 3, 2006 03:34 PM
