Electrical Replacement of Xenon Bulb
Old Oct 6, 2010 | 01:38 PM
resipsamcs's Avatar
resipsamcs
I have a 2003 MCS with Xenons. I'm looking for some lower cost/affordable options for replacing a burned out low beam bulb.
Can you fit a non-xenon bulb without problems? If so, any recommendations?
Thank you in advance for any responses.
Old Oct 6, 2010 | 01:47 PM
tvanhouten's Avatar
tvanhouten
Below is a link to a site you may consider ordering from. Keep in mind that you should consider ordering new bulbs for both sides, not just one side, Otherwise you will end up with different colors until the new Xenon bulb breaks in. Even after the break-in period, you may notice different shades of color because of OEM vs. aftermarket brands.
This site also provides the option of different Xenon colors: stock yellowish color, purple, or blue.
http://www.plasmagarage.com/D1S_D1R_HID-headlights.html
tvanhouten
Old Oct 6, 2010 | 04:38 PM
resipsamcs's Avatar
resipsamcs
Thank you for the link
Old Oct 6, 2010 | 07:47 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Are you sure the bulb is bad? Is it intermittent or simply never lights? Did you try moving the bulb to the other side to see if the problem moves too? There is an igniter (I hope that is not your problem) and a control box that could also be bad. I am trying to prevent your getting a bulb that doesn't solve the problem.
Rich
Old Oct 7, 2010 | 09:11 AM
resipsamcs's Avatar
resipsamcs
Thanks Rich, I will run through those checks. The low beam is out and has stayed out, not intermittent. I'll swap bulbs tonight and see what happens.
Len
Old Oct 9, 2010 | 09:36 PM
donjulio's Avatar
donjulio
If you need xenon bulbs, get some from ebay. I bought mine for about 20 bucks each. They're about 3 years old now and still running fine, so its not crap quality. Don't pay 200+, splurge on mods
Alkaidovich
Jan 30, 2021 01:35 AM
Rai1gun
R60/R61 Stock Problems/Issues
Jan 11, 2016 05:52 AM
AZN Optics
Aug 16, 2015 11:52 PM
