R56 Problem at 120k. Plz help
Old Feb 10, 2016 | 09:01 PM
Badchoice's Avatar
Badchoice
I have a 2008 r56s with 120k miles. Recently I've been having a intermittent misfire with a loud popping/banging coming from the exhaust. It only happens at WOT from around 3500-4500 RPM 2nd-6th gear. The vehicle idles fine and have no cold start problems. Timing chain and HPFP has been done at 110k. The car is completely stock. The codes are p0300, p0301, p0302, p0303, p0304 and not all at once. Sometimes just one code and other times maybe 3. When it doesn't happen the engine feels strong. Maybe a clogged cat or o2 sensor? I really don't want to throw parts at the car if it doesn't make sense. Thanks
Old Feb 10, 2016 | 09:32 PM
renchjeep's Avatar
renchjeep
With misfire codes like that, I would be thinking coils and/or plugs. HPFP just being replaced, I would probably not think that would be the cause, especially since you are not getting low fuel pressure codes. Another thought....have you had the valves walnut blasted or cleaned in any other way?
Old Feb 11, 2016 | 06:47 AM
Blasting and checking the coil and plugs . For them all to be bad I would be a Carbon cleaning is due. For the O2 sensor , you will see a decrease in MPG, or a sudden drop. Clogged cat with sometime show a very hot exhaust temp reading.
https://www.northamericanmotoring.co...-cleaning.html 81292208038
Old Feb 11, 2016 | 08:50 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
+1 on carbon clean up. At that mileage, if you haven't done it or know when it has been done, I'd get it done and see if this clears up your misfires. You'll want to do this clean up about every 50k miles. Once the build-up reaches the maximum tolerable level, the engine will begin to run rough and misfire. You may have a rough idle, poor acceleration, stalling or single to multiple cylinder misfires.
We have a DIY HERE that can help you.
888.280.7799 | 6am - 5pm PST
Old Feb 11, 2016 | 03:48 PM
Badchoice's Avatar
Badchoice
Does it make sense to do the carbon cleaning even though I don't have any cold start problems. The misfires go away if I continually to hammer on the throttle. Like it gets hot and clears up.
Old Feb 11, 2016 | 03:49 PM
PelicanParts.com
Vendor
Yes, it is a good idea to do a carbon clean up every 50,000 miles. The down side to direct injection (what your MINI has) is the lack of fuel spraying on the back of the intake valve. This removes the cleaning effect port fuel injection engines get, a real benefit new engine designs need.
Old Feb 12, 2016 | 05:09 AM
I have done it personally on my R56 MCS and you could feel the difference, its good maintenance and will improve mpg an hp. Especially if it never been done.
Old Feb 12, 2016 | 07:17 AM
Sstrickstein's Avatar
Sstrickstein
What is. Normal exhaust temp reading? I've got an app that lets me read this.
Old Feb 12, 2016 | 07:55 AM
https://www.northamericanmotoring.co...is-normal.html
Old Feb 18, 2016 | 03:17 PM
Badchoice's Avatar
Badchoice
Ended up being my spark plugs going bad oil in 30K miles
Old Feb 22, 2016 | 11:00 AM
Thanks for the update, Bad coil ? Or just spark plugs ?
Old Feb 22, 2016 | 08:09 PM
MiniMagoo's Avatar
MiniMagoo
I have a 2007 r56 that keeps spinning off codes of p0300, p0301, p0014, and p0014p. Sometimes it will spin one or all. I have no power, lose power, or sometimes I have a ton of power. I've replaced coils and spark plugs, a few sensors, and I'm at a loss. Could this be build-up as well?
Old Feb 22, 2016 | 09:09 PM
Badchoice's Avatar
Badchoice
Mine lucky ended up only being the plugs. Do you have cold start problems? When do you get the misfires? Can you cause the misfire to happen? p0014 have you changed out your camshaft position sensor?
Old Feb 23, 2016 | 06:58 AM
MiniMagoo's Avatar
MiniMagoo
Do not have any cold start problems other than when the battery is drained from a small clicking and beeping sound when the car is shut off. I've replaced the two sensors on top of the motor on the drivers side, not the two on the passenger side. I've pulled them and cleaned them which didn't make any difference. As for the misfire, the car will lose power in the pedal. The misfire happens at random.
Old Feb 23, 2016 | 07:51 AM
PelicanParts.com
Vendor
Would you say that your MINI idles poorly? The multiple misfires could be a sign of carbon build up. How many miles are on your R56 and have you ever done a clean up? P0014 is 'B' Camshaft Position Timing Over-Advanced or System Performance (Bank 1). I have seen some individuals clean or replace the VANOS with success, but it could be a timing issue. Some info HERE and HERE.
Old Feb 23, 2016 | 08:04 AM
Thats along the lines, when you done the plugs , coils, and evevrything else , the next step is to have the carbon done , if its never been done, then its time.
tchain
Feb 19, 2018 06:10 PM
nrfitchett4
Feb 11, 2016 08:43 AM
Samtrak
Jan 30, 2016 09:00 PM
alexs3d2
Jan 24, 2016 07:51 PM
bananamini
Jan 21, 2016 12:10 PM
