R56 Exhaust Questions
Old Feb 10, 2016 | 09:17 AM
2011BlackR56's Avatar
2011BlackR56
Exhaust Questions
Should I do a muffler, resonator, and 2nd cat delete? How much would it run average to get the work done?
Old Feb 10, 2016 | 11:56 AM
Try to contact a couple exhaust shops in your area, tell them what you want to do, Are you doing pretty much a build up straight pipe, if so it will take time to fab up and then mount in. Most of the cost is the labor, not materials . Pipe is pipe.
Old Feb 10, 2016 | 01:57 PM
2011BlackR56
Will it sound good?
Old Feb 10, 2016 | 02:07 PM
It will be loud and will drone if custom straight all the way back. Unless they change it up or do something to it. Your back hatch might vibrate a bit under certain revs. I would do a JCW or milltek non res and call it a day.
JCW
https://www.northamericanmotoring.co...st-to-mcs.html
https://www.northamericanmotoring.co...e-highway.html
Old Feb 10, 2016 | 02:09 PM
2011BlackR56
It will be loud and will drone if custom straight all the way back. Unless they change it up or do something to it. Your back hatch might vibrate a bit under certain revs. I would do a JCW or milltek non res and call it a day. JCW https://www.northamericanmotoring.co...st-to-mcs.html https://www.northamericanmotoring.co...e-highway.html
thank you! I'll look into it!
Old Feb 10, 2016 | 02:17 PM
You are welcome.
thebombardier's Avatar
thebombardier
What's your end goal? Performance or sound or both or what?
Old Feb 11, 2016 | 06:10 AM
2011BlackR56
Performance and loud. I'm wanting to do a stage 2 maniac tune.
Old Feb 11, 2016 | 06:20 AM
JCW with resonator delete is loud , nice sound and pops and cracks. The milltek non res is loud also. But not as loud as a full straight pipe ( but then you have drone and vibrations in the back ) .
Old Feb 11, 2016 | 07:15 AM
thebombardier
If you want to do stage 2 you'll need a catless/high flow cat downpipe as well as an exhaust system. I don't know if the stock JCW exhaust is up to the task. The Invidia Q300 system (which I have) is a popular choice around here. It drones a bit more than something like a Milltek but it gets the job done and is significantly cheaper than most systems out there. As for a downpipe there are plenty of used ones on the market here. You can also message a user on here with the name MarioKart. Mario sells super high quality downpipes, and is a Manic dealer if you happen to live in/near California and need a tuner. Between Mario's downpipe and the Invidia system my car is really loud, and drones quite a lot. It's all about whether you are comfortable with that. There's also the loudest option which would be a full custom straight pipe. That would drone a ton but get you the most performance and might be the cheapest option depending on the shop and how much they charge. Keep in mind your state's emissions regulations as well. if you live in a state that does sniff tests or visual inspections for emissions, you'll fail unless you swap in the stock exhaust components for the inspection. If your state does OBDII tuning the manic tune will get rid of the check engine light and you can pass. Or Mario's downpipes don't throw a light to begin with because of how he spaces the O2 sensors
Old Feb 11, 2016 | 07:17 AM
2011BlackR56
Awesome yeah and no I live in Dallas but I know good mechanics to help me out with the project
Old Feb 11, 2016 | 11:27 AM
Gipper's Avatar
Gipper
If you want to kill the drone with a catless downpipe and Invidia system - https://www.northamericanmotoring.co...ne-solved.html
Eric
Old Feb 11, 2016 | 05:19 PM
GAT's Avatar
GAT
Check the classifieds, Ive seen some decent cat-back units for sale. I personally have a Borla cat-back and love it. I don't have a downpipe but according to MarioKart, a well known member and Manic tuner on this forum, the downpipe would increase sound by approximately 15-20%
Old Feb 12, 2016 | 12:52 PM
MarioKart's Avatar
MarioKart
Vendor
Try going catless before getting a new exhaust. You might like the sound. My favorite set up, that was deep, loud on the outside, but no drone inside the car was my stock JCW 2.25" exhaust with 4" tips. It also was good for over 300whp
mQubed Motorsport, Manic Tuning Dealer
Markbett
Jul 31, 2019 06:57 PM
koroshiya
R59 :: Roadster Talk (2012+)
18
Feb 16, 2016 08:36 PM
Sho Nuff
Feb 10, 2016 03:27 PM
miniuy
Feb 6, 2016 06:08 AM
haztronic
Feb 3, 2016 03:50 PM
