Coolant Brand Question
Old Feb 6, 2016 | 12:15 PM
mini4mo's Avatar
mini4mo
Is PEAK coolant ok to use or does it have to be BMW brand?
Old Feb 6, 2016 | 12:32 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Many brands claim to be compatible, personally I would just stick with OEM.
Old Feb 6, 2016 | 01:45 PM
mini4mo's Avatar
mini4mo
From my understanding,the BMW coolant is blue.
As far as I know,the stock coolant is green in my wife's Mini.Never been changed.
Old Feb 6, 2016 | 08:47 PM
sevin's Avatar
sevin
Just stick to OEM for coolant. You won't save much money or get any real performance benefits from other brands.
Old Feb 7, 2016 | 02:10 AM
Unbreakable Lump's Avatar
Unbreakable Lump
It doesn't have to be BMW brand, but it has to be the correct type. There have been major developments in coolant technology over the last 20 years with HOAT and OAT long life coolants. Unfortunately, those two new types of coolants are incompatible. Mixing them can cause coolant to gel and clog small passages in the cooling system and lead to major problems, up to an including the destruction of your engine.
The only way to be safe is to use only the coolant specified for your vehicle.
Old Feb 7, 2016 | 08:36 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
About all fluids, both BMW and MINI cross lines. The MINI coolant is blue. It may only look Green due to tank color, and having been diluted with a 50/50 blend of coolant and distilled water.
Old Feb 10, 2016 | 07:07 AM
+1 its concentrated Coolant and gets mixed 50/50 with distilled water. Sometimes with age and looking in the coolant tank it can have a tad shade of green, then you pour it out and its blue. G11 blue in the aftermarket. MINI factory comes in a big gallon so its easy to make 2 gallon of 50/50. Which does about most cooling jobs. Used on both my MINIs.
82140031133
https://www.ecstuning.com/Search/SiteSearch/82140031133/
Old Feb 10, 2016 | 09:52 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
BMW has issued a 1991 technical bulletin, 17-01-88-(1743), which details problems with what is known as silicate gel precipitation in engines. This is the 'green goo' that results as a consequence of an antifreeze over-concentration in the coolant, combined with hard water, and the phosphates commonly used in many antifreezes. BMW factory antifreeze has been formulated to prevent this problem of silicate drop-out without any coolant performance loss. This antifreeze contains no nitrites and no phosphates. The part number for a one gallon container is 82-14-0-031-133, use 50/50 with distilled water. Personally, I stick to using BMW coolant for this and other reasons. Just for ease of mind.
888.280.7799 | 6am - 5pm PST
Old Feb 13, 2016 | 06:28 AM
mini4mo's Avatar
mini4mo
Ok thanks everyone.
Guess I'll use the peak for my older vehicles.
Old Feb 15, 2016 | 08:32 AM
You are welcome.
R56YouSankMyBattleship
Feb 9, 2016 02:57 PM
Blues Trucker
Feb 9, 2016 02:14 PM
tennis_man
Feb 8, 2016 10:25 AM
Steffen.Johnson
11
Jan 14, 2016 06:13 PM
Nc_r53
21
Jan 14, 2016 05:15 AM
