R50/53 yaw sensor plug and play??
Old Jan 25, 2016 | 09:44 AM
audio131's Avatar
audio131
Hi. Have a 06 r53. If i buy a used yaw sensor from a another 06 is it plug and play .or will i need to have dealer reprogram something?
Old Jan 25, 2016 | 10:33 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
New they're pretty expensive as you can see HERE. If I'm remembering correctly they're usually encoded and have to be encoded by a local dealer to properly function.
888.280.7799 | 6am - 5pm PST
Old Jan 25, 2016 | 01:00 PM
Its here and it will have to be coded. Are you throwing a code ?
This is what it looks like , mounts near the DSC unit.
34526764018
https://www.ecstuning.com/Search/Sit...64018/ES63151/
Old Jan 25, 2016 | 02:10 PM
audio131's Avatar
audio131
Hi. Every time i hammer the throttle the dsc light comes on..figuring its a bad yaw sensor..not quite sure..i see them used on ebay cheap.but if not plug and play then they arent gonna be cheap because of needing dealer to program
Old Jan 25, 2016 | 02:13 PM
The DCS light comes on and flash when you loose traction, its when it stays on and solid, no matter if you turn the DSC off or on. When you turn it off the DCS light stays on.
Old Jan 25, 2016 | 02:19 PM
nkfry's Avatar
nkfry
1. What kind of tires do you have on right now?
2. Low temps will cause more tire slip.
3. The DSC will kick in on dry pavement on an 80* day if you take off hard.
I've never seen a faulty yaw sensor, they are in the car and protected from the elements. Are you sure it's a problem? The DSC light would stay illuminated if there was cause for concern. Sounds like you need to get in the habit of turning it off when you get in the car.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jan 25, 2016 | 03:36 PM
audio131's Avatar
audio131
Yes when I hammer it the light will stay on and I can't turn it off until I turn off the car
Old Jan 25, 2016 | 03:38 PM
audio131's Avatar
audio131
I actually like the way the car feels with It off
Old Jan 26, 2016 | 05:17 AM
So it does t one time and then on all the time ? I would get that scanned first ( good scan tool ) to see if its the yaw sensor or just a bad connection. Or you can get the actual fault code.
https://www.ecstuning.com/Search/SiteSearch/ES2975699/
Yea, when its off, its like a track day with no electronics holding you back, more raw.
Old Jan 26, 2016 | 06:58 AM
nkfry's Avatar
nkfry
I've seen more of these situations come back to needing a wheel speed sensor, than anything else. Unless you spilled the mondo Murican cup of Baja Blast from Taco Bell into the center console, I doubt you need a yaw sensor.
You could either find an oscilloscope and read each sensor to see if/which one is faulting, or wait for more of a hint, like an ABS light coming on.
Phone:586-792-6464
Old Jan 26, 2016 | 07:21 AM
audio131's Avatar
audio131
Will that Schwaben scanner read body control module?
Old Jan 26, 2016 | 07:30 AM
Yes, reads the faults. Could not get it to code yet, just reprogram a new one, but there will be some software updates that you do online with it in the near future, so its an expanding system.
Ultraviolet1
Sep 12, 2020 08:06 AM
R5609
Jul 21, 2016 08:43 AM
teinesina
Jan 22, 2016 11:44 AM
Ryan Cooley
Jan 22, 2016 05:27 AM
boydie
Electrical
Jan 19, 2016 08:41 PM
