R50/53 Speedo "glass" buzzing
Old Jan 6, 2016 | 09:40 AM
aslondon's Avatar
aslondon
My 2004 R50 has developed a vibration in the plastic "glass" of the speedo. I can stop it by putting my finger anywhere on the piece. Has anybody else had a similar issue and a fix? No, it's rather awkward driving around with one hand pressed on the speedo so that would not be a "fix"
thanks
Al
Old Jan 6, 2016 | 10:26 AM
TWISTER's Avatar
TWISTER
might sound weird, but does it have a glare? Some people replace theirs with antiglare lenses and it does rattle.
Just take it off, open her up and lay some padding around the edges
Old Jan 6, 2016 | 10:48 AM
aslondon's Avatar
aslondon
its the oem piece. I assume the silver ring just snaps off. Thanks for the info
Old Jan 6, 2016 | 10:50 AM
TWISTER's Avatar
TWISTER
No, you have to take it off and unscrew it from behind. Maybe you could put a bit of silicone in an edge
Old Jan 6, 2016 | 10:52 AM
aslondon's Avatar
aslondon
10-4 thanks
Old Jan 6, 2016 | 12:00 PM
Yea, you have to pop off the trim ring onto that lens. The trim ring and center cluster trim as a whole might not be screwed or snapped in all the way. Two screw that are torx head go into the bottom lip on the dash , make sure they are tight.
http://www.realoem.com/bmw/enUS/show...diagId=62_0392
#2 with those two screws and snaps in on the bottom.
http://www.realoem.com/bmw/enUS/show...diagId=51_5446
Old Jan 6, 2016 | 12:11 PM
aslondon's Avatar
aslondon
is there any trick to unsnapping the trim ring without removing the center section of the dash? My feeling was that I could put several pieces of either foam tape or felt around the inside of the trim ring and put it back on.
Al
Old Jan 6, 2016 | 12:18 PM
You could do that , chek the digram. or here
https://www.northamericanmotoring.co...ter-gauge.html
I took min out by the whole trim as the trim ring are in there pretty tight and i did not want to snap one of the tabs.
Old Jan 6, 2016 | 12:26 PM
aslondon's Avatar
aslondon
got it. Great video thanks
Robert Pritchard
R55 :: Clubman Talk (2008+)
Jan 29, 2016 05:12 AM
Oldswimcoachkt
14
Jan 19, 2016 10:58 AM
Unbreakable Lump
Jan 7, 2016 07:03 AM
Paul Yan
Jan 6, 2016 09:05 AM
DWooderson
R60/R61 Stock Problems/Issues
Dec 30, 2015 10:57 AM
