R56 When to replace rotors?
Old Oct 7, 2015 | 07:07 PM
mbwicz's Avatar
mbwicz
I'm just looking for opinions on when to replace rotors.
My car (08 MCSa) has about 1/2 brake pads left, and significant (but even) wear on the rotors. Both front and rear are below the 'minimum thickness' cast into the rotors. I'm strictly street driving this car, and braking performance remains strong.
I'm running EBC red pads, factory front rotors and WMW rear rotors.
Any opinions appreciated.
Have fun,
Mike
Old Oct 7, 2015 | 11:31 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Probably the last time the pads were changed would have been the time. I'd change them as soon as you can, I'd also put new pads on at the same time. Can't think of a more important component in a car than the brakes.
I change pads/rotors before they are due, what is the point in squeezing every last mile out of them?
Old Oct 8, 2015 | 02:42 AM
mbwicz's Avatar
mbwicz
Actually, the rotors and pads were changed together, I was a little surprised to see how much the rotors have worn. That is why I asked for other opinions.
Mike
Old Oct 8, 2015 | 04:25 AM
gjxj's Avatar
gjxj
are you measuring thickness yourself?
Old Oct 8, 2015 | 06:35 AM
ZippyNH's Avatar
ZippyNH
If the rotors we of legal, aka, above MINIMUM thickness when you put the pads on, they SHOULD be fine till the pads are done UNLESS you have a VERY AGGRESSIVE PAD, aka a racing pad...
Remember, the MINIMUM thickness measured WHEN NEW PADS ARE INSTALLED.....
one warning...if you ever notice your braking is poor, just replace the rotors and pads....pads are so cheap I would NEVER reuse pads on a new rotor.
Old Oct 8, 2015 | 09:32 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
We have a great Brake Pad and Rotor Specification Checking tech article here that may come in handy for you.
888.280.7799 | 6am - 5pm PST
Old Oct 8, 2015 | 05:39 PM
mini4mo's Avatar
mini4mo
Next time you replace the pads buy new rotors.
Old Oct 8, 2015 | 07:01 PM
Systemlord's Avatar
Systemlord
EBC Reds are tough of stock rotors especially on the drilled and slotted sport OEM rotors!
Tires, Wheels & Brakes
Sep 16, 2015 06:27 AM
daddyandmadi
Sep 15, 2015 08:07 PM
David.R53
Sep 13, 2015 03:44 PM
marc0011
Sep 10, 2015 10:04 PM
