R50/53 DSC Light and CE Light on P0340 Code HELP
Old Sep 8, 2015 | 03:52 PM
Steffen.Johnson's Avatar
Steffen.Johnson
I have done a ton of research on this forum and others and it seems people have had similar issues with there r53s but no one seems to actually share how it was fixed.
I have been complaining about the cold start problem recently and some people said its this and that blah blah blah but nothing. Recently I had the same issue and it set off the DSC and Check engine light at the same time. After starting and restarting a few times the code goes away but I had it checked today at autozone and they said it was the P0340 code for camshaft sensor. Could this be causing the issue? OR are they unrelated. Also how much will this cost me to fix, where do I start. Please help!! Thanks!
Old Sep 9, 2015 | 02:14 PM
Steffen.Johnson
Help!! Anyone!!!
Old Sep 10, 2015 | 10:25 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
With the P0340 code, symptoms can include:
Hard starting or no start
Rough running / misfiring
Loss of engine power
This with more information and possible solutions can be found here. After this, if you believe the camshaft sensor is the culprit, part here. There is also some good info in this thread here on NAM, which includes some instructions on the replacement.
888.280.7799 | 6am - 5pm PST
Old Sep 10, 2015 | 02:27 PM
Steffen.Johnson
Thanks so much pelican, after reading all the symptoms and forums it seems this is my exact problem. The car is going into the dealer for unrelated issues saturday so I will see what they quote me at for the sensor and installation as I no longer have tools or a garage.
How would i even get in there to check the connections and plugs? Sucks now that I moved from a house to a apartment but ill have to make due.
Old Sep 10, 2015 | 02:50 PM
Finhead's Avatar
Finhead
Super easy to get at the Crank sensor, #8 in this picture. It's directly below the fuel lines on the front of the engine side, between the engine mount and head. You would only need a 10m wrench to change it out.
Sorry after looking at it would be much easier and quicker to remove the mount first, so 16mm, 18mm and a 10mm. You would also need a jack for under the motor, so a few tools but not many.
Old Sep 10, 2015 | 03:11 PM
PelicanParts.com
Vendor
You're very welcome. Not having a garage and tools does kind of make things a bit more difficult, but hopefully they don't quote too much. It is, however, fairly easy to access, but you do need to support the the engine. Otherwise, you might be able to look around the area and visually inspect things. (I hit the camshaft sensor electrical harness connector in the photo for you to see).
Here is the part if needed: http://www.pelicanparts.com/catalog/..._pg2.htm#item9
Old Sep 10, 2015 | 06:49 PM
Steffen.Johnson
Thank you both for the information. That is something I think I could definitely do on my own. I was under the impression that on my 2006 r53 the sensor was on the front of the engine block behind the radiator. I feel stupid now. So is this the CAM we are talking about and the CRANK is the one I was thinking?
Old Sep 10, 2015 | 06:56 PM
Steffen.Johnson
Like the one here in this pic?
Old Sep 10, 2015 | 07:16 PM
Finhead's Avatar
Finhead
Sounds like from the link Pelican provided it cold be either or maybe both. It lists as both could be at falt.
The Crank shouldn't be that much harder if you have a jack/stands you could get away with just moving the rad forward rather than draining and taking it out. Would require a philips screw driver and one torx screw driver a 8mm and 14mm and 16mm (I think for the bumpercarrier) socket/ratchet extentions. Bumper and bumper brace can come off in 20min easy. Then just edge the rad forward and you can get the crank sensor with a 10mm.
Up to about 5min in this video is where you would have to be. Little more work than a mount but not a crazy amount, and fairly basic really.
Old Sep 11, 2015 | 04:54 AM
Steffen.Johnson
Front End Service mode 2002-06 MINI Cooper/radiator/bumper removal howto - YouTube
Yea I am seeing that I guess the CAM is the one located on the side of the engine (near the engine mount) the CRANK is the one on the front of the engine behind the radiator. I think I could do the CAM myself but no way the CRANK as I have barely no tools or space anymore.
Pelican - Are you suggesting I try the connection first, then replace the CAM if need be and clear codes, then last resort an code still pops up then try rhe CRANK??
Old Sep 11, 2015 | 06:30 AM
PelicanParts.com
Vendor
Correct, the cam sensor is located on the passenger side of the engine and the crank sensor is located towards the front and requires a bit more effort to get to.
So, from the link I posted it suggested there could be wire issues or either of those sensors have failed. Since you don't have the tools and space to perform a full diagnosis you could try to see if any of loose connection or damaged wires, if not, then replace the cam sensor and see if that resolves your issue. You could also wait until Saturday for your appointment and have them confirm it's the cam sensor. However, from the thread I linked to it sounds like the cam sensor could be your culprit. From most of the threads I've run across with that code, the cam sensor fixed it.
Old Sep 11, 2015 | 06:28 PM
Steffen.Johnson
Ok that sounds like a good plan. I appreciate all the help you have been giving. I checked the wires, and plug today and it seemed like it was all good. Just to see if it was exactly what I was dealing with over the last month I unplugged the sensor completely and started the car up. EXACT same issue so I am thinking its a faulty sensor or wire harness. I plugged all back in tight, had autozone clear the code, and reset the ECU on my own. And nothing yet, I am going to drive to the dealer tmrw about 2.5 hours and ill see if the light or anything comes on. If not I might just have them run a test to see if it came back but so far I am pretty confident it is the CAM sensor.
Old Sep 15, 2015 | 08:56 AM
PelicanParts.com
Vendor
Great, Steffen. Sounds like you got things handled. It's my pleasure. Glad I could be of assistance. If you need anything else, please don't hestiate to ask.
Old Sep 19, 2015 | 07:17 AM
Steffen.Johnson
Will do thanks again!
Old Oct 28, 2015 | 10:08 PM
joylove's Avatar
joylove
Weird about the DSC light; I have the same thing and both started on the same day, code is the steering angle sensor.
Steffen Did you fix the DSC light when you fixed the sensor?
Old Oct 29, 2015 | 08:41 AM
PelicanParts.com
Vendor
Is your tire indicator on as well? Good quote about the steering angle sensor from this thread here.
The steering angle sensor is basically steering wheel position. In order for the DSC to operate correctly, the vehicle must know where the front wheels are pointing.
Some really good info about the steering angle sensor issue here, which was indeed the culprit and once replaced the issue was fixed. See if your issue sounds the same as it might be a good place to start.
Old Oct 29, 2015 | 08:50 AM
joylove's Avatar
joylove
Tyre light is not lit, but I'll still read the links after work.
What's the right why to support the engine for the sensor swap? I don't want to crack an oil pan or something.
Old Oct 29, 2015 | 09:05 AM
PelicanParts.com
Vendor
Steffen was getting a P0340, which indicated a CAM sensor issue. Are you getting this code as well? You're specifically getting a steering angle sensor fault so your issue may not be the same as Steffen's, but I could be wrong. Most of what I am finding about the steering angle sensor issue is combined with a tire pressure indicator light, but I did find this thread here and he didn't have that indicator one as well. Ended up being the angle sensor for him.
For the cam shaft sensor, there is a step by step process including where to jack it up in this thread here. Linked directly to the post.
Old Oct 29, 2015 | 09:39 AM
joylove's Avatar
joylove
Ah right yes I do have 0340 in the DME.
I Also have 5E5C (initialize runflat) and 5E1E steering angle sensor in the DSC. maybe Ido have a runflat issue.
I also have 5E16, 5E14 and 5E19 in the DSC but I suspect these go away when the steering angle sensor is working.
Old Oct 29, 2015 | 09:53 AM
PelicanParts.com
Vendor
Ok, just checking! Also, the runflat is noted in those threads as a symptom if the angle sensor is bad.
Old Oct 29, 2015 | 10:07 AM
joylove's Avatar
joylove
Deffo going to ask the RDC why it can't init.
Old Oct 31, 2015 | 08:51 AM
Steffen.Johnson
Old Oct 31, 2015 | 09:06 AM
David.R53's Avatar
David.R53
As to the engine mount question- if you look at the whole engine, there are two beefy engine mounts (aluminum castings) that hold the main weight of the block+tranny assembly from each end (left and right). Then there are two lighter weight mounts (high and low) that resist the torque reaction of the engine. It is one of these lighter mounts that is in the way of the cam sensor. You can remove and replace it (just two bolts) without supporting the engine --as long as you don't run the engine--. If you needed to take off the beefy engine mount (4 bolts + a nut) on the end of the block, you would definitely need to support the weight of the engine.
Old Oct 31, 2015 | 09:21 AM
joylove's Avatar
joylove
The top line failure is the RDC not the steering angle sensor. I may have a runflat issue
Old Oct 31, 2015 | 09:30 AM
Steffen.Johnson
Interesting.. Sorry about all those smileys I only meant to put one?
