R56 AC only works at idle
07 MCS 66k.
Recharged the system, AC blew nice and cold while driving main roads. After about a 40 minute highway drive, I noticed the AC getting warmer and warmer, to eventually not being cold at all. Weird thing is, is when I come to a stop light or really low speed, it gets cold again.
Any ideas on where to start?
I would recommend going to Harbor Freight and picking up a set of gauges they will tell you all you need to know. It sounds like you overfilled the system and will need to re-do it. You can do a fair amount of damage by overfilling. The gauges will take out a lot of the guess work. I very much doubt you have a problem with the pressure switches, given that it sounds like they are doing their job. See link below for the gauge kit.
http://www.harborfreight.com/a-c-man...set-92649.html
are your gauges any good? it sounds exactly like a overfill problem maybe get another set to see if something is wrong with your set.. and was the system empty before you put the pound in? did u use a vacuum pump to remove all refrigerant? did you weigh what you pulled out?
Too much oil from adding the oil+r134a cans can cause a similar issue...many cans have oil plus gas...if you don't shake the can as you add it, or keep adding cans over a couple years to make up for a leak, the oil volumes keeps getting higher....
Drivetrain Won't hold idle after work performed
Lt. Dan
Aug 10, 2015 08:23 AM
