R56 Diverter/bypass Valve
Old Apr 26, 2015 | 12:49 PM
enoe01's Avatar
enoe01
I just bought a 2007 Cooper S. The CEL came on and the code it was throwing was p28AA diverter/bypass valve plausibility. My car does not have the response it once had now that it is in LIMP MODE... Can anyone direct me to where I go next, replace etc. I have looked and cant seem to find the answer anywhere. Please help me out.
Erik
Old Apr 26, 2015 | 01:18 PM
Roxspin72's Avatar
Roxspin72
Replace it.
The diaphragm inside the DV is most likely torn. I believe that the N14 2007-2010 used a DV that is now upgraded on the N18 models 2011-2013...
Check sites like WMW, Out Motoring, Etc.. Good luck and enjoy the install, it can be a B!$@£ at first LOL...
Old Apr 26, 2015 | 01:22 PM
enoe01's Avatar
enoe01
I am looking at the Forge model here is the link. Will this be the one I need to get?
http://www.forgemotorsport.com/conte...oduct=FMDVR56A
Old Apr 26, 2015 | 02:46 PM
TVPostSound's Avatar
TVPostSound
Unless you are modded, Forge is overkill. Also $290.00
Try this to replace as OEM:
http://www.ecstuning.com/Mini-2007-C...16A/ES2768088/
Or this as an upgrade:
http://new.minimania.com/part/G2NME3...e-Dv-2007-2010
Old Apr 27, 2015 | 06:51 AM
That genuine one is the newest design. Looks like they changed the design again.
http://www.ecstuning.com/Search/SiteSearch/11658636606/ES2768088/
Old Apr 27, 2015 | 07:56 AM
Grizld700's Avatar
Grizld700
I have this on my '07:
http://www.battletuning.com/shop-5/g...iverter-valve/
It works with the stock one, but replaces springs and uses a metal diaphragm so you don't have to worry about your torn one (assuming your is torn).
Old Apr 27, 2015 | 02:50 PM
enoe01's Avatar
enoe01
Awes thanks guys! I bought the new OEM model for now to get me going and when I decide to do more mods I will get an upgrade. Thanks again!!
Thanks to ECS Tuning for the assistance and I am looking forward to installing your product! I will let you know how the install goes and how the new part works!
Erik
Old Apr 27, 2015 | 07:59 PM
Systemlord's Avatar
Systemlord
Have you ever been in a MCS that had the Forge deverter valve? The purpose behind the Forge DV is that it reacts much faster than the stock DV, the stock DV dumps more boost than is nessisary. Your turbo using the Forge DV increases your turbos responsiveness and you dump less boost in between shifts. Just ask anyone who owns the Forge DV, they will tell you the same thing.
Old Apr 28, 2015 | 05:03 AM
Welcome. We carry Forge Motorsport also.
olson187
Oct 21, 2015 05:25 AM
Fordgt4
Oct 10, 2015 10:42 AM
Southern Marylander
Oct 1, 2015 07:53 AM
Emnotek
Sep 29, 2015 07:37 AM
Nicefeet
Sep 24, 2015 06:53 PM
