Running non-sensor wheels question
Old Nov 29, 2014 | 04:09 PM
Longgone's Avatar
Longgone
I have a `07 Cooper S with 16" wheels that have air pressure sensors. I'm looking at going with a little wider tire on a 17" rim like a R98 or similar. My question is, can I run a non-sensor type wheel on my car without having an indicator light on all the time?
Old Nov 29, 2014 | 05:17 PM
Jayoni's Avatar
Jayoni
You will get the indicator on all the time with the non sensor wheels.
Old Nov 29, 2014 | 06:31 PM
Longgone's Avatar
Longgone
Thanks, I was afraid of that. I understand there are some wheels that don't have a flat surface for mounting the sensors. Unfortunately it seems to be that every wheel I like doesn't accept a sensor.
Old Nov 29, 2014 | 06:41 PM
Michael Cutler's Avatar
Michael Cutler
If memory serves me properly, this issue was corrected by placing all four sensors in an airtight PVC tube, pressurizing the tube to nominal tire pressure, and putting it under a seat. A Search of the forums should give the details of exactly how it was done.
R98's are TPMS compatible. They were the OEM wheels on my '07 S, (November build date.)
Old Nov 29, 2014 | 08:15 PM
Longgone's Avatar
Longgone
Thanks for the reply. This is good news on both accounts. I'll look for the thread/s that expound on the subject.
Old Nov 30, 2014 | 05:29 AM
Drivehard's Avatar
Drivehard
If memory serves me properly, this issue was corrected by placing all four sensors in an airtight PVC tube, pressurizing the tube to nominal tire pressure, and putting it under a seat. A Search of the forums should give the details of exactly how it was done. R98's are TPMS compatible. They were the OEM wheels on my '07 S, (November build date.)
+1 on this. It does in fact work.
Sent from my iPad using NAMotoring
Old Nov 30, 2014 | 06:34 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Some OEM MINI sensors have a soft membrane on the bottom and small tabs on the end designed to sit above the inner barrel's surface which is allowing air pressure to that membrane. (post 2010 models I believe ) So in some cases, you may be able to make them work...seen it done on a set of R-85's.
Old Nov 30, 2014 | 08:11 AM
Zillon's Avatar
Zillon
I successfully installed a set of 2010+ sensors on a set of R84 X-lites, it can be done.
Old Nov 30, 2014 | 08:41 AM
Longgone's Avatar
Longgone
Thanks for the replies. I've been eyeing a set of Anthracite R90's. So if the possibility of using them exists now (without a warning indicator always lit) I may spring for them.
Old Nov 30, 2014 | 12:30 PM
ashchuckton's Avatar
ashchuckton
I believe your MINI can coded do that TPMS is disabled. No the dealer will not do this. Helix did a bunch of coding changes on our clubman & IIRC that was one of the coding options that could be done.
jeffbeckhudd
Aug 29, 2015 09:11 PM
Mini'mon
Aug 16, 2015 04:15 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
ki7hy
Aug 12, 2015 07:07 PM
