Windshield washer hose broke
Old Sep 23, 2014 | 01:09 PM
Tomas_siba's Avatar
Tomas_siba
Hi guys, anyone know where I can find this hose? It is connected on the inside of the hood, just left side connector broke, thank you
Attached Thumbnails Windshield washer hose broke-image-3607945414.jpg   Windshield washer hose broke-image-788083935.jpg
Old Sep 23, 2014 | 08:11 PM
BubbaJCW's Avatar
BubbaJCW
Dealer?
Old Sep 23, 2014 | 11:23 PM
Tomas_siba's Avatar
Tomas_siba
Yea I could but wanted to avoid going there, I was hoping someone could direct me to a website, I will look at ecs tuning tomorrow. Thanks
Old Sep 24, 2014 | 07:02 AM
Looks like its all one hose.
http://www.realoem.com/bmw/enUS/show...diagId=61_2183
#3 61667220827
http://www.ecstuning.com/Search/SiteSearch/61667220827/
Old Sep 24, 2014 | 08:43 AM
Tomas_siba's Avatar
Tomas_siba
So the one in the link on your website is the hose that connects from 1st washer on the hood to the second washer and splits in the middle?
Old Sep 24, 2014 | 09:00 AM
Its the whole #3 long hose from the reservoir ( down by clip #6) that then Y to go to both spray nozzles.
#2 and #1 are the nozzle and not included in #3.
Old Sep 24, 2014 | 12:20 PM
Tomas_siba's Avatar
Tomas_siba
thank you, you guys have it the cheapest, but i dont need the entire hose, if i cant find just the two hoses that connect to the Y i will order it from you guys.
Old Sep 24, 2014 | 12:30 PM
You are welcome.
MINI has universal cable hose, but it cost more then that whole piece, and there is no part for just that section. I guess the plus is you ensure no other leaks in the Y line current and down the road.
Old May 20, 2018 | 08:04 PM
antjeon's Avatar
antjeon
Tomas_siba,
I know the post is old but, I have the same issue. I was wondering if you had found the parts to repair it? Thanks in advance!
Tony
Old May 21, 2018 | 08:05 AM
triumph442's Avatar
triumph442
Same here Tony, I actually had the exact same piece break and i'm glad i found this on the home page because it's exactly what i'm looking for.
Old May 23, 2018 | 10:46 AM
antjeon's Avatar
antjeon
Triumph,
Hey, if you're still looking for the piece, this is what I found:
Mini Cooper Windshield Washer Angle Piece 4-pack Oem Gen1 R50 R52 R53
Mini Mania says that they found it to fit Gen 1 and Gen 2.
Hope that helps!
Tony
Old May 23, 2018 | 04:35 PM
ammodave's Avatar
ammodave
If all you need is the hose and not the connectors, you can buy bulk hose at any auto parts store. Take a piece of the old hose with you to make sure you get the right size. Common hose connectors ( tees, elbows, etc.) are also available.
Old Feb 16, 2020 | 04:02 PM
Scott K's Avatar
Scott K
You don't even need to replace the angle piece. I just pulled the broken 90 degree angle piece off (it's a press fit) and connected the hose straight into the nipple on the bottom of the squirter. In my case, I had a roll of new hose in the garage, so I replaced the entire segment of hose. Just use a little Windex to lube the hose and nipple and work it on carefully so you don't break the nipples. Replacing the hose is a good idea because the hose on our 2012 Cooper was gooked up inside with some black stuff. One nozzle was gooked up so used a safety pin to clear it out and aim it... and now it's working perfectly!
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
GAT
Oct 4, 2015 07:27 PM
MINI Stupor
Oct 1, 2015 11:36 AM
