Windshield washer hose broke
Looks like its all one hose.
http://www.realoem.com/bmw/enUS/show...diagId=61_2183
#3 61667220827
http://www.ecstuning.com/Search/SiteSearch/61667220827/
#3 61667220827
Its the whole #3 long hose from the reservoir ( down by clip #6) that then Y to go to both spray nozzles.
#2 and #1 are the nozzle and not included in #3.
You are welcome.
MINI has universal cable hose, but it cost more then that whole piece, and there is no part for just that section. I guess the plus is you ensure no other leaks in the Y line current and down the road.
Triumph,
Hey, if you're still looking for the piece, this is what I found:
Hope that helps!
Tony
Mini Cooper Windshield Washer Angle Piece 4-pack Oem Gen1 R50 R52 R53
Mini Mania says that they found it to fit Gen 1 and Gen 2.Hope that helps!
Tony
You don't even need to replace the angle piece. I just pulled the broken 90 degree angle piece off (it's a press fit) and connected the hose straight into the nipple on the bottom of the squirter. In my case, I had a roll of new hose in the garage, so I replaced the entire segment of hose. Just use a little Windex to lube the hose and nipple and work it on carefully so you don't break the nipples. Replacing the hose is a good idea because the hose on our 2012 Cooper was gooked up inside with some black stuff. One nozzle was gooked up so used a safety pin to clear it out and aim it... and now it's working perfectly!
Steffen.Johnson
42
01-25-2023 02:47 PM
GAT
10-04-2015 07:27 PM
MINI Stupor
10-01-2015 11:36 AM
