considering wheels-need assistance
Hello!
I'm looking at getting these wheels:
http://www.discounttiredirect.com/di...=Car%2FMinivan
Probably the lighter colored ones.
I've always kept stock wheels...my question is, what is offset and would I need to really worry in this case?
Any help, helps!!
Noel
Any help, helps!!
Noel
I would suggest using a wheel offset calculator like this: http://www.1010tires.com/Tools/Wheel-Offset-Calculator
If you have a big brake kit you might need a wheel spacer depending on the wheel design (3-5mm spacer seems to be typical).
And I will tell you that my 2009 Clubman S (R55) I fit a 17x7.5" +42mm offset wheel fine as-is (Volk SE 37K), and it also fits fine with a 5mm spacer. It also fit fine with a 10mm spacer. However with a 12mm spacer the rear tires were rubbing the plastic outer fender if I hit a big bump or dip in the road.
The wheels you're looking at appear to be 16x7 with a +40 offset. I think they'll fit fine, but I am not really familiar with the r53. Just use the calculator.
Haven't even though of 17's. I'll have three sets of wheels, (S-Winders for sale).
But, car will be lowered slightly with HR springs, (waiting for install) and Koni Yellows.
Depends what you are after: form or function? Smaller will likely be lighter/faster...
These are the wheels I bought, if you get your wheels make sure they come with centering rings.
http://tinyurl.com/oaux9wy
The 40 offset should be fine with 16" wheels as long as you don't go with super tall sidewall. I had 17" x 7", 38 offset, with 215/40 tires and H&R springs with a slight rub in the rear that I was able to resolve with a little inner wheel well plastic trimming. 40 offset will give you a couple mm of more clearance. Thus 16" should be no problem.
As others have suggested, I would also look at 17" wheels and tire selection available in 16 and 17. You might find that you have more tire options in 17".
Filmy
15
Sep 26, 2015 07:04 PM
R50/53 What is up with my 2005 r53?
rustof
11
Sep 25, 2015 10:35 AM
CooperT
R60/R61 Stock Problems/Issues
Sep 22, 2015 12:54 PM
R50/53 R53 ignition and Ac issue
shahriar35
Sep 12, 2015 08:31 PM
