R50/53 New header and Detroit bpv now rough idling bunch of codes please help!
Old Aug 6, 2014 | 01:34 PM
austin327's Avatar
austin327
Hey all I need some help I have an 04 r53 just purchased obx header and a Detroit tuned bpv. Car ran perfect before now it idles rough had it scanned and got a all of these codes 1689, 1242, 1109. I've checked every hose sensor fuse and can't find anything wrong please help
Also the power steering and brakes aren't working either
Old Aug 6, 2014 | 01:59 PM
SpiderKnight's Avatar
SpiderKnight
Not an expert..
It could be that your car needs to re-adapt to the new vacuums and pressures with the new stuff you've added.
However, the brakes not working seems to indicate a vacuum leak near the throttle bottle, I think that's where the vacuum tube from brakes connect.
Power steering is weird, I can't see it being related but maybe somebody else has some insights to this.
Old Aug 6, 2014 | 02:13 PM
ZippyNH's Avatar
ZippyNH
Sounds like you need to check your work...seriously....you yanked everything apart...time yo look at everything you touched...missing gasket maybe?
....check for any gaskets that might not be seated right (did use ALL NEW ONES RIGHT)....OBX welding is usually pretty bad...the flanges tend to be pretty bad...many folks use soft crushable gaskets to get a better seal....but new OEM ones will usually work...
No power steering usually means the alternator is not working....check the wires going to it....you might have cut/broke one....
Old Aug 6, 2014 | 02:16 PM
ZippyNH's Avatar
ZippyNH
One more thought....look around the bpv....there are vacume lines there....and one might have gotten reversed or cut....also make sure everything in the area is sealed right...a misseated gasket can cause major issues too...
Old Aug 6, 2014 | 04:06 PM
austin327's Avatar
austin327
Yes I have gone through every gasket wire vacuum line I can find I have taken both the header and valve back out to see if I missed anything is it possible I need to get a tune or something to make it run properly. I installed cat back. Intake. Alta 15% pulley ignition box spark plugs and wires all with no issue
Old Aug 6, 2014 | 04:24 PM
ZippyNH's Avatar
ZippyNH
https://www.northamericanmotoring.co...242-p0300.html
Look at this....is the tab on the part by the bypass valve broken?
Old Aug 6, 2014 | 04:30 PM
bavmotors's Avatar
bavmotors
Check your intercooler to horn rubber connections if your having vacuum leak issues.
Old Aug 6, 2014 | 08:25 PM
Kr4nG's Avatar
Kr4nG
recheck your fuses make sure you didnt pop one somehow. i did a header and popped my engine fuse #2 car wouldnt start
Old Aug 7, 2014 | 05:42 AM
austin327's Avatar
austin327
I will double check that tonight does anyone have a picture of the tab we. I checked the intake tube it seemed to be in good shape but reading that post sounds just like my issues
Old Aug 7, 2014 | 06:36 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
Normally intercooler boots are off and need to be reseated correctly. Give us a call if you need help. While the OBX header is a pile off crap it's not the reason unless you didn't hook up O2 sensors and or damaged something. it's a vacumm leak somewhere there.
Chad
Detroit Tuned
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Teh
Aug 22, 2022 04:37 AM
mdutton11
14
Oct 26, 2015 01:47 PM
Marco Guardado
Sep 15, 2015 01:22 AM
Aug 25, 2015 07:11 AM
Lt. Dan
Aug 10, 2015 08:23 AM
