R50/53 How to make your Magnaflow louder in 10 seconds.
Old Jun 27, 2004 | 10:41 AM
Sarcux's Avatar
Sarcux
Open the hatch and drop the seats. I was carrying one of our creepers (bonecreeper.com, shameless plug) to test some wheels at our molder on thursday... and its a bit too long to fit in the back, so I had to run with the hatch open... that Magnaflow is deafeningly loud at that close of quarters at load.
Might be a good way to do a different Exhaust Shootout (Ryan, Chad & Greatbear) at the '05 Dragon... this time having the car under load. If people are brave enough to hang out the back, heh.
Just an idea. If it weren't for the exhaust fumes getting sucked in, I'd drive like that more often.
Old Jun 27, 2004 | 11:23 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Here is another way to make things louder from the exhaust.
Remove the rear seat bottom pad.
On each side at the corners are the bolts that attach the rear seat belts.
Take each one out and that will reveal a hole that goes through to the outside of the undercarriage. If left open they allow lots of noise in.
I had removed the bolts to install the rear seat belt attachment for Schroth harnesses and I drove with the bolts out. Very loud.
Not recommended.
Old Jun 27, 2004 | 12:24 PM
Bisch's Avatar
Bisch
Yeah, I pulled out my entire interior last week, just for fun. (who am I kidding, I was going to the dragstrip). I left just the drivers seat. That M'flow sho wuz loud!
Old Jun 27, 2004 | 12:34 PM
minihune's Avatar
minihune
By removing the interior how much weight did you loose?
Did you pull out the rear window wiper too?
Loose the AC and the stereo?
Be uncivilized
The audio nuts are the opposite-
adding sound deadening material for reduced vibration and minimizing noise.
It's pretty heavy if you do it right.
Old Jun 27, 2004 | 04:27 PM
The_Beastmaster's Avatar
The_Beastmaster
The Magnaflow on my 525it is pretty loud, too. It has a drone from 1k to 2k then it gets a little better. Liveable, but not sure about what passengers think.
Old Jun 27, 2004 | 05:48 PM
Sarcux's Avatar
Sarcux
Man, removing the entire interior? That's a job.
Old Jun 27, 2004 | 07:21 PM
Ryephile's Avatar
Ryephile
Sarcux also has his Magnaflow tips FLUSH with his rear valence, maximizing its loudness, whew!
Old Jun 27, 2004 | 07:55 PM
TwOMINIs's Avatar
TwOMINIs
MMMMMM....Magnaflow....music to my ears.
I too have the tips flush with the valence, but I have found with this set up I dont have the dreaded "drone" that so many have whinned about
click pic for better view :D
His, Chile RED over, Madness intake, Magnaflow exhaust, Helix 15% Pulley & RDR Swaybar
Hers, Electric Blue / Union Jack on top and BONE Stock
theblackfalcon
Oct 11, 2015 09:49 AM
honderpilot
Aug 31, 2015 02:53 AM
JPMontes3
Aug 24, 2015 07:15 AM
damncajun
Aug 17, 2015 08:25 PM
ASRman
Aug 13, 2015 09:33 AM
