lose the run-flats
lose the run-flats
I'm looking to change tires. My question is what size tires are an option
for me to repace my 205/45-17 run-flats? The OEM size doesn't give me much choice in replacements. I know that you have to consider clearence problems as well as speedometer problems. Has anybody been successful using a size different from the original equipment tire? The run-flats are deffinitely something that I can do without.
Thanks for any help.
Yokohama has two very good choices: The Parada Spec-2 and the AVS ES100, both available in stock 205/45-17 sizing. I'm currently running the Parada in this size. Much better dry grip than OEM, and mush more predictable at the limit, at the expense of less wet grip and increased road noise.
HTH,
Ryan
HTH,
Ryan
Just replaced my stock 16" with 205/45/17 Toyo Proxes 4 ... awesome all around.
Super quiet, great grip and an unbeliavable change in comfort level from the stock runflats. I cannot say enough about them.
$104 each at edgeracing.com
I've got the 16" ES100s about a week ago and they are great except that here in Los Angeles, I now suffer from serious tramlining. This never happened with my runflats, or atleast not as serious.
Originally Posted by coopersport
I just replaced my Pirelli run flats with Yokohama AVS ES 100 215/45 17's and the car is much more comfortable. The tires are quieter than the runflats and they are much smoother over the bumps.
What do you do about a spare? or do you just risk it?
Can you use stock rims for non-runflats?
Questions
Tramlining is your front wheels follow the grooves cut into the concrete freeway (common in California) so that the car steers with some instability moving slightly side to side.
Most runflat owners note this esp with the 17" wheels but it can happen with non runflats too. Make sure you tire pressure is adjusted and you are not running too much on the high side. Try 32 or 33 psi and see if that helps.
I have Yokohama ES100 215/45-17 and get minimal tramlining.
Runflats are harsh riding due to the very stiff sidewalls. But they are safe.
If you hit a pothole at speed, the damage may be transmitted to your rim from the runflat so be very careful. Road hazzards may be extra trouble and lead to costly tire and rim repairs/replacements. If your roads are bad please drive at the appropriate speed to avoid hazzards.
I sold the S-Lites/Dunlop runflats immediately upon buying my Mini. I had been running 16" Rotas with 215/45 Falken Azenis for daily use and autocross, they are now reserved for just autocross days to save wear. I have a set of Kosei K1-TS now with 215/45-17 Kumho MX's for the street. The MX is a very good handling tire, and seems to work better with standing water and wet roads than the Azenis.
I had a set of the ES-100s on my Evo, they weren't as grippy as the Yokohama AO46s that came on it, but they rode quieter and smoother on the highway and were an awesome all weather tire. They did show some tram-lining tendencies, likely due to the larger size (255/40s) and the tread pattern, but it was minimal.
Alex
Heh... Alex, I mounted them on 17 by 9" Enkei RPM2s, purchased from you guys May '03. I believe I had discussed the fitment with you on EvolutionM.net, as well as talking to some people on the phone there who were surprised that they fit under the Evo fenders.
Alex
I was running the stock 16" Runflats and experienced minimal tramlining. With the ES100's it's about 300% worse. I keep hearing people say it's minimal with the ES100's, but I have to disagree since with my runflats it was practically non existant before. Now when I'm on the freeway doing anything from 25 to 60 mph, the car bounces side to side very uneasily--like it's dancing. As soon as I transition to freeway that doesn't have the rain grooves, it's fine, and very smooth. Same with surface streets. It's fine, so I know it's not a tire mounting issue. Just something to think about. The tires are great in all other aspects--sticky, comfortable, affordable! :smile:
Originally Posted by lurch70
Excsuse the ignorance, but what is tramlining?
My 2002 mcs came, as spec'd by me, with 195/55/16 dunlop all season sport 5000 dsst.I am now at 34k and they are smoked.I am looking for a non runflat replacement option and will carry the stupid donut in a bag that takes up half my trunk
My question is : is there a tire to fit my r88(10 spoke OEM-see my sig) wheels that will give me all season performance in non run flat, that will give me 60 - 70 k ? and what will that little donut tire cost me at the dealer?How much can I vary from the original size on these rims and what are the ramifications of going up or down?Thanks in advance for any response. Jock
As a similar option to the exisitng runflats ... I highly recomend the All Season Ultra High Performance Toyo Proxes 4 ...
had them for 3 weeks and am super happy. They come in 16 and 17 inch versions for the MINI.
USA-RET
Oct 27, 2015 10:42 AM
eliseo1981
Sep 30, 2015 07:57 PM
