R56 OBDII readings
OBDII readings
I have a 2008 JCW. Noticed some power issues (just seemed sluggish) and boost gauge was acting funny. Checked the hose and sure enough it was split. I fixed that and then plugged in an OBDII Bluetooth tool to get the readings on my phone.
Vacuum was at -14 and max boost was at 7psi. That seems awfully low and car still seems sluggish. Anybody know what the boost should be around? Does this maybe indicate a leak?
Also, anybody know a OBDII plugin tool that works with IOS? I had to borrow my kids Android phone to get readings off the one I have.
Engine was replaced around 7k miles ago, for what that's worth.
Boost is variable based on conditions. I see anywhere from ~9-14 on my 2010 MCS. Also make sure the car was fully warmed up as it will reduce output until warm.
Sent from my XT926 using NAMotoring
For iOS I strongly recommend this wifi adapter:
1.) http://www.newegg.com/Product/Produc...9SIA1EF0SN5964
paired with this app:
2.) DashCommand from Palmer Performance. It was on sale for $9.99 on the App Store. Palmer Performance also has a free version of ScanXL that you can download from their website to a laptop running Windows. You can then use the laptop to connect via the wifi adapter if you prefer.
Your boost readings do seem low.
For iOS I strongly recommend this wifi adapter: 1.) http://www.newegg.com/Product/Produc...9SIA1EF0SN5964 paired with this app: 2.) DashCommand from Palmer Performance. It was on sale for $9.99 on the App Store. Palmer Performance also has a free version of ScanXL that you can download from their website to a laptop running Windows. You can then use the laptop to connect via the wifi adapter if you prefer. Your boost readings do seem low.
I waited for the coolant temps to increase and then it ran around 14 psi under load. All seems good now. Thanks for the input
Navigation & Audio HK Replacement With New Components
Filmy
15
Jun 6, 2023 06:27 AM
potterstein
Sep 13, 2015 09:57 PM
