R50/53 It wasn't coolant. then what is that sweet smells?
Old Dec 30, 2013 | 11:18 AM
mikeson's Avatar
mikeson
Hi guys,
I posted a while ago as this link.
https://www.northamericanmotoring.co...ant-smell.html
After like 4 months, there is no coolant leak( I mean level of coolant hasn't been changed at all nor never had over heat issues)
There is no coolant drop or level changes, so I guess there is no coolant leak.
However, I still smell that sweet coolant. (like I drove 20miles and park and after 10 or 20min. when I start engine, I can smell it(sweet))
or while I drive sometimes I can smell it.
I checked heater core and there is no coolant drop at all.
What do you guys think?
Old Dec 30, 2013 | 11:55 AM
ZippyNH's Avatar
ZippyNH
Coolant....
You can have the vent cap release pressure.... And not be leaking coolant.
Old Dec 30, 2013 | 05:33 PM
Da_Ghost's Avatar
Da_Ghost
Originally Posted by ZippyNH
Coolant....
That's all I can think of as well. The stock cap is known to vent some on top of the reservoir, leaving a film on it. I have a Forge tank with the stock cap and it's hard to keep it clean at times because of it. Since it's only vapor, the level won't be affected.
There's not a lot of things that can smell like coolant. If there isn't a leaks, I wouldn't be too concerned.
Old Dec 30, 2013 | 06:25 PM
AZdsrt's Avatar
AZdsrt
As others stated, coolant. You could have a very small leak in the heater core, that would be enough to produce a strong smell. Happened to me..
Old Dec 30, 2013 | 06:26 PM
Capt_bj's Avatar
Capt_bj
small leak on the overflow tank dripping to the heat guard below
feel around to the back side of the tank at the seam and look for signs of cooked off coolant on the heat shield
Old Dec 30, 2013 | 11:35 PM
Debi's Coop S's Avatar
Debi's Coop S
This was the problem we had, I replaced the overflow tank and no more issues....
Old Dec 31, 2013 | 07:37 AM
Ian Landesman's Avatar
Ian Landesman
Are you the first owner? Maybe someone spilled cola in the vent before you got it? Weird...
Old Dec 31, 2013 | 08:18 AM
RockAZ's Avatar
RockAZ
Beehive? Nah, must be venting coolant at the reservoir tank.
Old Dec 31, 2013 | 09:11 AM
mikeson's Avatar
mikeson
Thank you for advising guys. =)
I checked the tank and it is clean.( I replaced like 5 months ago)
no visual leak, no level in tank has been changed.
I will keep you guys update if I find something.
Thank you again and happy new year guys.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
drrigg
May 27, 2022 03:31 AM
Colt45Magnus
Oct 1, 2015 04:08 PM
papawhiskey
Sep 30, 2015 02:50 PM
