It wasn't coolant. then what is that sweet smells?
Hi guys,
I posted a while ago as this link. https://www.northamericanmotoring.co...ant-smell.html After like 4 months, there is no coolant leak( I mean level of coolant hasn't been changed at all nor never had over heat issues) There is no coolant drop or level changes, so I guess there is no coolant leak. However, I still smell that sweet coolant. (like I drove 20miles and park and after 10 or 20min. when I start engine, I can smell it(sweet)) or while I drive sometimes I can smell it. I checked heater core and there is no coolant drop at all. What do you guys think? |
Coolant....
You can have the vent cap release pressure.... And not be leaking coolant. |
Originally Posted by ZippyNH
(Post 3860325)
Coolant....
You can have the vent cap release pressure.... And not be leaking coolant. There's not a lot of things that can smell like coolant. If there isn't a leaks, I wouldn't be too concerned. |
As others stated, coolant. You could have a very small leak in the heater core, that would be enough to produce a strong smell. Happened to me..
1 Attachment(s)
small leak on the overflow tank dripping to the heat guard below
feel around to the back side of the tank at the seam and look for signs of cooked off coolant on the heat shield Attachment 153264 |
Originally Posted by Capt_bj
(Post 3860471)
feel around to the back side of the tank at the seam and look for signs of cooked off coolant on the heat shield |
Are you the first owner? Maybe someone spilled cola in the vent before you got it? Weird...
Beehive? Nah, must be venting coolant at the reservoir tank.
Thank you for advising guys. =)
I checked the tank and it is clean.( I replaced like 5 months ago) no visual leak, no level in tank has been changed. I will keep you guys update if I find something. Thank you again and happy new year guys. |
| All times are GMT -7. The time now is 10:35 AM. |
