R50/53 Rebuild is almost done... cant figure out where one plug goes, any ideas?
Old Aug 25, 2013 | 02:30 PM
vox633's Avatar
vox633
Hey guys, i just put a rebuilt engine back into my r53 MCS, i have one plug left on the wiring harness; i cannot for the life of me figure out where this goes...
Any ideas?
Rebuild is almost done... cant figure out where one plug goes, any ideas?-x7ruvjp.jpg
Old Aug 25, 2013 | 02:48 PM
vox633's Avatar
vox633
Shitty picture... sorry guys. The inside of the connector is exactly the same as the power steering pump coolling fan plug. the two pin grey/white. It reaches around the back of the block to the starter... thats about how far it goes, though i dont think thats where it goes as there is no plug...
Any ideas would be appreciated as i am at my wits end :(
Old Aug 25, 2013 | 03:29 PM
fr0mmagna's Avatar
fr0mmagna
What about the fuel tank breather valve ? Right next to the engine ground strap... Its branded as Delphi , so maybe...
Old Aug 25, 2013 | 03:32 PM
vox633's Avatar
vox633
Hmm the purge canister? This plug is on the drivers side of the car... Or is there something im missing? Could this be for the vehicle speed sensor? its about 10 inches long, so it has to stay on the drivers side of the car in the engine bay :/
Old Aug 25, 2013 | 03:36 PM
fr0mmagna's Avatar
fr0mmagna
Does the car work without the wire connected ??
If you have a wire diagram, check the colors to see where they're supposed to go ??
Old Aug 25, 2013 | 03:37 PM
vox633's Avatar
vox633
OOOO, the colours might be a good idea. I dont have my bentley manual with me but i believe it has wire colours.
vox633's Avatar
vox633
Also, no clue if it works without it connected :P i dont want to connect the battery without it
Old Aug 25, 2013 | 03:38 PM
fr0mmagna's Avatar
fr0mmagna
You could check the engine ECU and compare. See what fuse it goes to, which will help quite a bit.
fr0mmagna's Avatar
fr0mmagna
If its a two wire switch, shouldn't be "too serious" :-)
Old Aug 25, 2013 | 03:44 PM
vox633's Avatar
vox633
Oh ****. I didnt think of that at all...Gah. Okay ill see if i can see something in the fuze box.
Old Aug 25, 2013 | 03:46 PM
fr0mmagna's Avatar
fr0mmagna
I specialize in low voltage wiring as my career, if they're colored, just made your day that much easier ! See if you get symptoms without the harness connected and if you do, you now know where it goes.
Good luck!
Old Aug 25, 2013 | 03:47 PM
vox633's Avatar
vox633
Thanks a lot man!
Old Aug 25, 2013 | 04:01 PM
fr0mmagna's Avatar
fr0mmagna
Keep us posted tho!
I know my advice is mediocre but might as well try it. Maybe you can get it running by tomorrow.
Old Aug 25, 2013 | 04:27 PM
ACallahan's Avatar
ACallahan
Old Sep 6, 2013 | 05:28 AM
vox633's Avatar
vox633
AC COMPRESSOR, DAMN IT!
Haha, that was annoying. Thanks guys.
Shane Wendel
Electrical
Aug 20, 2015 06:50 AM
danraabe
Aug 18, 2015 09:32 AM
Super Coop
Aug 17, 2015 05:09 PM
calebmil
Aug 7, 2015 05:54 AM
