R56 Changed Spark Plugs! '10 MCS
Old Aug 20, 2013 | 09:51 PM
pbedrosi's Avatar
pbedrosi
Only 41,000 miles but thought it was a good cheap maintenance item and I was itching to get my hands dirty.
Used the original NGK Laser Iridium's,ordered from Amazon. Got the socket from Sears online, all good to go.
I didn't have much expectation since miles were relatively low for spark plug change. so far with 1/2 tank gone I can say that my fuel economy is notably better. My miles driven + distance to empty is typically around 490 miles, but now around 510 (theoretical). I keep a record of MPG so lets see where it lands after a refill.
The car does respond and idle a tad better, but its hard the discern. If you've been debating chaning your plugs I would go for it. Don't wait for "100k".
The old plugs didn't look so bad, even coloring. Here are the pics.
Old Aug 20, 2013 | 10:12 PM
MiniWii's Avatar
MiniWii
Those aren't bad at all, you should've seen my plugs on the M5 after 35k miles...
Old Aug 21, 2013 | 01:00 AM
Systemlord's Avatar
Systemlord
Actually it's 60,000 miles before you're supposed to change the plugs in a MCS, the bone stock MC you change plugs every 100,000 miles. That's what it says in my manual.
Old Sep 26, 2013 | 02:10 PM
Farmermc's Avatar
Farmermc
I changed my set out at 55,000 miles and felt the difference. Smoother and torqy.
I got OEM NGK for $12 bucks a piece off ebay, and for the money will be changing every 30,000 miles at max...less if I feel like it.
Old Sep 27, 2013 | 06:30 AM
MiniErik's Avatar
MiniErik
Changing mine this weekend, im at 45,000 miles.
With my evo I had I changed them every other oil change and had 2 steps colder
Old Sep 28, 2013 | 05:18 AM
richardsperry's Avatar
richardsperry
I did mine at 40K also. Did you measure the gap? I had one plug at .038" and the others were in the low 0.03x range.
Gapped new plugs to 0.028" and it's good to go.
Old Sep 28, 2013 | 08:51 PM
The_Blurr's Avatar
The_Blurr
OEM NGK's were 12 $/piece!? .....man I just got Brisk racing silver plugs for 13 $/piece gapped them to 0.019" and my MCS is running like a champ... much more responsive in sport mode!
Old Sep 28, 2013 | 09:18 PM
AdrenaliNate's Avatar
AdrenaliNate
Do you mind sharing where you got Brisks for $13/ea?
Old Feb 24, 2014 | 10:25 PM
pbedrosi's Avatar
pbedrosi
with few thousand on the plugs my mileage now sucks. Not sure if the plugs are it. I will remove and inspect soon.
Bublik
Feb 18, 2023 11:09 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
Sikness
R57 :: Cabrio Talk (2009+)
Aug 20, 2015 06:00 PM
maniacalmorgan
Aug 19, 2015 08:44 AM
yashmack
Aug 15, 2015 10:16 AM
