R56 Charging Press Code of death p2096
hello guys
i dont know if any of you guys have experience the Charging press code of death that i cant seem to find the solution to this. i have pressured tested the car i have uninstalled my AP and installed it disconnected it the battery with the ap uninstalled and installed it again and it always comes up.
any help?
here is the Code
i have ALTA FMIC, ALTA Intake Filter and AP with Stage 1 tune
please helpp me
any help?
here is the Code
please helpp me
You might still have a bad O2 sensor even though you replaced it. I would check to make sure it is good and tight. Also it could be your cat is going bad. How many miles on your MINI? Both of these could still be under warranty if you are less the 80k.
i took it to the mechanic i was there personally when they pressured test it and nothing. the i told them i have an upgrade Front mount they checked that and nothing. idk what else to do.
i have read online that people hae taken it to MINI dealership and they have updated the ECU and that it self makes the code go away would that work?
well i just hit 99k yesterday and i have a 2 year extended warranty
Yes that's what am doing I mean they covered my 02 sensor I'll take it back to the mechanic if anything I'll go to mini so they can update the ECU and see if that works
polotska
Aug 23, 2015 03:03 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
