R50/53 Outrageous
Outrageous
Does anybody find it outrageous that a motor mount can cost $330? I personally think this is the ultimate scam. How can anyone justify paying that for a motor mount? I am completely baffled by this...
I can help you find the part and give you some options I was going to ask the same thing about the year and model , but bram beat me to it.
Thanks Greek, I guess I was memorized by the sig stubby antenna ball and did not see it.
#3 The one above is for the 12/2003+ Part number 22116778610
http://www.ecstuning.com/Search/22116778610/
#7 is the lower engine mount, You might want to check that also if its separated from the rubber on the larger section.
Lower Engine Rubber Mount Part number 22116756406
http://www.ecstuning.com/Search/SiteSearch/22116756406/ES41645/
On the transmission side there is #1 mount which there is a part number for the automatic and manual transmission version for the Cooper S.
Transmission Support Bracket / Mount Manual transmission Part number 22316754422
http://www.ecstuning.com/Search/SiteSearch/22316754422/
Transmission Support Bracket / Mount - Auto transmission.
http://www.ecstuning.com/Search/SiteSearch/22326768207/
Thanks and hope that helps now.
$330 for an engine mount... yes a bit outrageous.
Try paying $120 for a tiny engine shock for a Mercedes Diesel engine... two per engine. That's ridiculous.
Thankfully the MINI mount has aftermarket versions
Check with the vendors on this site, you have one on this thread you can trust, for better parts at lower prices.
Also, get to know RockAuto.com.
^This. Like, say, us!
If it's the upper one, it's filled with hydraulic fluid, so it's not like most motor mounts, where it's just ''rubber''. Apart from stock, there's a couple aftermarkets ones if you don't mind the extra bit of vibrations.
Also the upper mount 22116778610 will tend to leak the black fluid and can be seen on the inside rail, and sometimes on the back side , if not seen from the front, that is the visual way to see its bad.
was UNDER $200 installed....took about 20 minutes...no appointment needed at my favorite independent shop that does MINI work....
You can buy non-OEM ones for less and DIY it....but a 2 year warranty on a MINI branded part that seems to last about 30,000 miles MIGHT mean I get a second one for free.....
Sorry for the delayed response folks, been having computer issues. The mount I was referring to is the Vibre-Techincs. I am on my 3rd OEM mount from Mini and is leaking again. I didn't want to go with a solid mount because of the NHV. I saw this one and thought it might be a good alternative until I saw the price. Has anyone told that company you can buy a big screen TV for that price? http://new.minimania.com/part/NME470...-MINI-COOPER-S I wander how many they have actually sold? That's ridiculous...
They have been much discussed on NAM and getting popular: https://www.northamericanmotoring.co...atechnics.html. Considering that you've already gone through 3 OEM mounts, maybe it isn't quite so ridiculous after all.
They are just starting to pick up vendors in the U.S. (previously only available direct from the UK). OutMotoring also carries it now: http://www.outmotoring.com/vibra-tec...ount-road.html
[QUOTE=rkw;3778050]They have been much discussed on NAM and getting popular: https://www.northamericanmotoring.co...atechnics.html. Considering that you've already gone through 3 OEM mounts, maybe it isn't quite so ridiculous after all.
You have a point- Thanks for the info. Wow you can go into information overload with that thread! I still cant believe that price but, I may have to bite the bullet. Just pi$$es me off that its just one more thing I have to spend money on with this car
. Gen 1 refreshed R53. Its been a good car so far. I've had it since new. It will be 9 years old next week with 59K miles. I guess its going to need stuff as it gets older (kinda like me, lol). I just had to change out the control arm bushings with urethane ones a couple months ago. I also have the low speed fan issue, oil pan leak, and sender leak problems to deal with. Better than a car payment though
. Gen 1 refreshed R53. Its been a good car so far. I've had it since new. It will be 9 years old next week with 59K miles. I guess its going to need stuff as it gets older (kinda like me, lol). I just had to change out the control arm bushings with urethane ones a couple months ago. I also have the low speed fan issue, oil pan leak, and sender leak problems to deal with. Better than a car payment though Thread
plkdb
Classic Mini Talk
20
Nov 12, 2007 03:12 PM
Yucca Patrol
Dec 2, 2002 07:41 PM
