R56 Detaching the wipers
Old Feb 16, 2013 | 10:23 AM
genik's Avatar
genik
Is there some video i can see regarding how to detach the windshield wipers?
Old Feb 16, 2013 | 02:20 PM
Capt_bj's Avatar
Capt_bj
you mean get the blades off of the arms?
just push the little clip and slide the blade towards the arm base
apart it looks like
after market arms will have adapters in the package allowing you to fit the correct one into the J of the arm
OR are you asking about getting the rubber insert out of the arm . . .
Old Feb 16, 2013 | 03:07 PM
genik's Avatar
genik
Capt_bj.... many thanx very impressive way to guide me through this. And if its not to hard for you, yes, i also need some help on the rubber, how to take it off and how to place the new one.
Old Feb 16, 2013 | 03:24 PM
Capt_bj's Avatar
Capt_bj
I'll to that tomorrow (dinner is almost ready now)
but better - take my advice and buy some replacement blades at any decent auto part store
replacing the inserts is a pain . . .
Old Feb 16, 2013 | 03:31 PM
genik's Avatar
genik
oups, it is a pain? I already have a pair here!
Old Feb 16, 2013 | 04:16 PM
Capt_bj's Avatar
Capt_bj
OK
from this pic
at one end you'll see some metal tabs
you need to squeeze these so that you can push the rubber part out to the left (in this pic)
you will end up with a rubber blade and two metal stiffener bars
to replace you need to hold the stiffeners into the rubber slots and thread THAT back into the blade .....
Or buy a set of AMCO or PIAA or BOSCH or or or blades which will just click into the J of the arm . . .
replacing inserts is just a PIA
Old Feb 16, 2013 | 05:53 PM
Porthos's Avatar
Porthos
Oh yeah the stock inserts hurt a lot to install.
Old Feb 17, 2013 | 12:12 AM
genik's Avatar
genik
i dont understand where to squeeze so that the old rubber is released? by squeeze you mean to make those tabs to open so that the blade is released? and if so, ill have to do that in all 6 pairs of tabs that the metal wiper has?
Old Feb 17, 2013 | 01:49 AM
genik's Avatar
genik
ok i got a pair of Guard Wiper Blade Refills and it was a piece of cake. Easy to mount, the rubber was on a plastic guide so there metal stiffener bars were not needed, all went smooth and easy. There was no squeeze needed cause at the end the guide had a fastening mechanism! Thanx a lot for all the help!
Old Feb 17, 2013 | 08:48 AM
Mannylove's Avatar
Mannylove
Nice
apart it looks like
I gotta say Capt. That's awesome. The fact that you took the time to put this together and then did another to help a member......your aces in my book.
Old Feb 17, 2013 | 08:54 AM
genik's Avatar
genik
I wish there was a like button so i could press it a thousand times for expressing my thanx to Capt, its true what you did was exceptional... thanx again!
PsychoRallye
21
Feb 17, 2019 06:08 AM
Scm68
Jan 27, 2016 12:33 PM
Hobine
Oct 7, 2015 04:52 PM
Samhillrocks
Sep 29, 2015 12:55 PM
Sep 3, 2015 12:24 PM
