something to worry about?
Old Nov 2, 2012 | 10:15 AM
eaglebeagle's Avatar
eaglebeagle
I noticed while peeking under the hood, the right side of the plastic cover(?) on top appears not as flush as the left. almost like its loose, only not. I can push it flat, but it doesnt stay there. left is flush and doesnt move. see pics.
right-loose side:
Left:
I'm probably worrie dabout nothing, but just thought it looked odd and i should check.
Old Nov 2, 2012 | 02:57 PM
Fly'n Brick's Avatar
Fly'n Brick
Don't try to stash so much weed in there.
Less smart a$$ response:
(Did you check the retaining screw for tightness or stripped threads? If you push down on the panel and the screw doesn't move then it needs a little bit of righty tighty. If the screw does follow the up and down then the receiving threads are more than likely stripped. If so a bit of foil or wire solder can take up the slack.)
Old Nov 3, 2012 | 10:48 AM
eaglebeagle
haaaaa.
the screws/bolts FEEL tight. I dont have the tool to tighten them if they're slightly loose, but they definatly don't feel like they're going anywhere. Whats under there anyway?
Filmy
15
Jun 6, 2023 06:27 AM
Fourflys
43
Oct 20, 2015 09:42 AM
honderpilot
Oct 11, 2015 06:35 AM
eliseo1981
Sep 30, 2015 07:57 PM
Adam Bradbury
Sep 28, 2015 04:15 PM
