R58 Buzzz
Old Sep 8, 2012 | 01:31 PM
Cruzer214's Avatar
Cruzer214
Buzzz
Ive been meaning to ask this since I got my coupe. Does anyone know what the buzz noise is when you open your door? Sounds like it comes from rear of car.
Old Sep 9, 2012 | 05:04 AM
BillTheCat's Avatar
BillTheCat
Nothing buzzes when I open my door. Do you have a bee's nest in your tailpipe?
Wait, are you talking about when you UNLOCK the doors with the remote? That buzzing would be the actuator in the boot unlocking that particular lock.
Old Sep 9, 2012 | 07:37 AM
minirab's Avatar
minirab
I think what you might be talking about is the motor for the rear spoiler,
mine does it on start up every time.
Old Sep 9, 2012 | 11:32 AM
Cruzer214's Avatar
Cruzer214
It only happens if I dont open the door for awhile, if I open the door a minute later it doesn't buzz. Maybe it does have something to do with the spoiler who knows.
Old Sep 9, 2012 | 12:03 PM
Marioalex24's Avatar
Marioalex24
I believe that buzz is the fuel line or pump working when you open the door. My mini does as well as the two m3s I used to own. I'm not 100% sure which one was it, but I ask my mechanic and he said it was normal, but I forgot which one was it. Some cars make the buzz louder than others.
Old Sep 10, 2012 | 01:45 PM
rosvick's Avatar
rosvick
It's the fuel pump priming the fuel system. I can promise you that.
Every vehicle makes that noise when you initially put the key into the ignition and turn it to the "on" position (enging still off). You'll hear that "buzz" noise.
Because MINIs have a push-button start system, the fuel pump has to prime before anything can happen, so they just prime it whenever you unlock or open one of the doors. The car is assuming you're getting ready to jump in and drive!
Old Sep 10, 2012 | 01:57 PM
astroBlackMetallic_Mini's Avatar
mine buzzes too, but it comes from my speedo i think! (R53)... i know the fuel pump isnt in the dash!
Old Sep 11, 2012 | 04:23 PM
Cruzer214's Avatar
Cruzer214
This sounds like a good reason! Thanks!
Old Sep 12, 2012 | 05:15 PM
rosvick's Avatar
rosvick
Oh, mine buzzes like crazy while it's in motion. I'm slowly disassembling the interior and isolating as much as I can find.
But, as far as the "buzz" while parked, it's the fuel pump.
Old Sep 13, 2012 | 05:05 AM
rosvick,
when i took some of my car apart to install GTmat (sound deadener) i found several door clips that were "loose". they were properly seated in their holders on the door panel, but had the slightest movement in them. when hitting certain rpms, the car of course vibrates, causing those little bits to also vibrate. i put a tiny square of GTmat under the clips and put it all back together. now those little buzzes are gone! (in the door anyway ;P)
Old Sep 14, 2012 | 05:54 AM
rosvick's Avatar
rosvick
astro,
Yeah, I've been finding the same thing with Broadspeed. I think I've gone through around eight feet of foam tape to isolate the door clips, electrical connectors, and anything else that's rubbing up against anything else in the doors. I'll have another test drive this morning to see if I got most of it!
msjulie33
Apr 28, 2011 08:38 PM
herbie hind
Jul 3, 2007 03:02 AM
d-mini-ero
29
Jan 19, 2004 04:52 PM
jamesday24
South East - Florida
May 6, 2003 07:43 PM
