Drivetrain yessss!!!!
Old Jul 1, 2007 | 04:11 PM
herbie hind's Avatar
herbie hind
yessss!!!!
thx randy webb of webb motorsports for the 05 crank pulle/harmonis damper . the difference is awsome . noise wise the sound of exhaust and sc is all i hear now ; as compared to the clatter and garbage can full of bolts i used to hear . some buzzzing is gone also . best money spent .
Old Jul 1, 2007 | 05:08 PM
JIMINNI's Avatar
JIMINNI
Not sure what you are saying. Are you saying you installed a 05 OEM crank pulley on your car? What year is your car now? I have been thinking of replacing my crank pulley for a lighter 05 and up pulley. Is this what you did?
Old Jul 1, 2007 | 05:12 PM
Wake|MCS's Avatar
Wake|MCS
I did this too and didn't notice too much of a difference. Only a slight difference in RPM pick-up and drop-off, keyword there being SLIGHT... Worth it though as the old ones are a POS...
Old Jul 1, 2007 | 05:51 PM
herbie hind
yeah rpms were only slightly better . but my old one was definately on the way out . making all kinds of noise .
Old Jul 1, 2007 | 11:05 PM
ED955S's Avatar
ED955S
Same question as Jiminni. Is this the Webb lt. wt. crank pulley or 05 OEM?
Old Jul 2, 2007 | 12:56 AM
SharoSC02's Avatar
SharoSC02
I have also been told that the 05 crank pulley is much lighter than the prior years and does work better. However I have been comtemplating in going with the 05 crank pulley simply because of the old rule, if it's not broken don't fix it.
Or maybe I'm looking at this the wrong way since the change or the fix will make the car better.
Old Jul 2, 2007 | 01:31 AM
latte hiatus's Avatar
latte hiatus
My bet is on the '05 OEM.
Old Jul 2, 2007 | 08:26 AM
JIMINNI's Avatar
JIMINNI
Thats what i've been wondering too. Mine seems to run fine, but have been told " lighter is better " , well I did know that but..... And I dont really want to go with the aftermarkets as they don't have the harmonic balancers.
Old Jul 2, 2007 | 08:48 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Thanks Herbie!
The crank pulley I sent him was an '05-'06 OEM unit. None of the OEM pulleys have harmonci balancers, they use a rubber for vibration damping.
We have done over 200 lightwieght WMS crank pulleys without a single engine failure (or other major problem)!
Hope that helps,
Randy
Old Jul 2, 2007 | 12:21 PM
JIMINNI's Avatar
JIMINNI
Originally Posted by RandyBMC
Thanks Herbie!
Hope that helps,
Randy
Wow! thank's for the clarification . But wait a sec., then why did he buy a OEM unit??
Old Jul 2, 2007 | 12:37 PM
70spop's Avatar
70spop
...they use a rubber for vibration damping.
Smooth or ribbed?
Old Jul 2, 2007 | 01:40 PM
herbie hind
05 stocker .
Old Jul 2, 2007 | 01:42 PM
herbie hind
cause i'm a scaredy cat .
Old Jul 2, 2007 | 06:39 PM
JIMINNI's Avatar
JIMINNI
Good 1, me 2 .
Old Jul 2, 2007 | 07:49 PM
meenie_me's Avatar
meenie_me
how do you know if your crank pulley is not working properly?
Old Jul 2, 2007 | 10:10 PM
JIMINNI's Avatar
JIMINNI
If your engine runs, it's working. Are you saying it might be making noise?
Old Jul 3, 2007 | 03:02 AM
herbie hind
the pre 05s had a nasty hbit of shreading . mine was quite noisy too.
drstevenj
Aug 29, 2002 06:37 PM
