Drivetrain methanol
Old Jun 30, 2007 | 08:58 PM
herbie hind's Avatar
herbie hind
methanol
other than boost juice ; where's everyone buying their meth?
Old Jul 1, 2007 | 10:24 AM
latte hiatus's Avatar
latte hiatus
The biodiesel folks are pretty helpful with finding sources of methanol.
http://www.localb100.com/testbatch/buyingmethanol/
Checking the regional forums for your locality on BioDieselNow.com worked out for me. I ended up finding a local race gas distributor that sold methanol for $3.25/gal.
http://www.biodieselnow.com/forums/d...aspx?GroupID=6
How's the installation on your WI kit coming along?
Old Jul 1, 2007 | 04:07 PM
herbie hind
just looked at it today. it's late though. i had to do rear brakes and paint rotors plus replaced the 04 harmonic with an 05 (what a difference ) !!! so i'm just planning the install now . gonna need a thicker floor for it for sure . say 3/8 plywood .
Old Jul 2, 2007 | 01:22 AM
latte hiatus
That plywood is going to add quite a bit of weight!
I wedged the tank on the passenger side of the boot (without drilling into the floorboard and strapping it down yet) by spacing out the emergency equipment that are usually kept in there, and no sloshing or shifting in hard cornering. I'm thinking something like these may help:
http://www.griotsgarage.com/catalog....2530&SKU=77121
The extra weight will be retained on the passenger rear, instead of distributed entirely along the rear like a piece of plywood.
For peace of mind, though, it's hard to beat fabbing a new floor mat for the trunk. Let me know if you have a schematic? I'm interested to see how involved it is, since I haven't done any woodworking in a few years now.
Old Jul 2, 2007 | 07:02 AM
shooler's Avatar
shooler
From some crazy looking chick on the corner I bought mine at a local race shop. They carry it in bulk, so I brought a 5 gallon container in and filled it.
Old Jul 2, 2007 | 07:20 AM
04SDmini's Avatar
04SDmini
I'm a chemist... I walk into the lab, grab a 4L bottle our of the flam cabinet and off we go
Old Jul 2, 2007 | 09:44 AM
El_Griton's Avatar
El_Griton
I get mine from your mom! oh snap!
Old Jul 2, 2007 | 01:44 PM
herbie hind
nice !!! she works on our corner too .
Old Jul 2, 2007 | 01:45 PM
herbie hind
wow that was waaaaay harsh .
Old Jul 2, 2007 | 01:53 PM
herbie hind
i'm just gonna make a template with cardboard . then screw strips to the underside of the (cut to shape piece) to get it up a little so i can run the wires and the lines under it . it won't get crimped that way . and the lines can dissapear rt. at the tank . one of the guys picked up keyed power from the aux. power plug . i tested it and it's a good way to go . i'll check the bently to see if the fuse can take it . there's a 10 amp in the kit so gotta make sure the other fuse isn't too small . which would indicate wires that will be too small . and voltage drop ,then burnt up motor . hopefully it's a 10 cause the wire looked like the same gauge .
Old Jul 2, 2007 | 05:21 PM
latte hiatus
Wow, thanks for the reminder! I hooked up my WI by tapping the 12V switched ignition power for the cigarette lighter in the boot, but it didn't occur to me to find out what the amperage on that line was - I merely operated under the assumption that it was 15A (F32) like the one beneath the toggle panel in the cabin.
Edit: Just looked in the Haynes manual, and I can't find a wiring diagram that includes the 12V adapter in the trunk.
Old Jul 2, 2007 | 06:05 PM
herbie hind
that's the same spot . in fact you're probably the guy i'm thinkin' of ; thx !! cool!! if it's 15 up front it's probly 15 out back . nice. i'll drill a hole beneath the false floor to that panel and it'll be invisible . and i think i'll follow the main hot wire to the front as others have done . how'd you run yours? someone on here ran theirs in the cabin . i'm too lazy for that by far .
Old Jul 3, 2007 | 07:52 AM
latte hiatus
No, probably wasn't me - I just did the install myself this past weekend.
I ran the wires by following the OEM wiring from the trunk to the positive terminal in front. There was a rubber gasket in the boot by the battery that was perfect for routing the lines under the car - it comes out right by the exhaust in my case, though, so I'll add some heat wrap to the hosing there. Followed the OEM wiring along the driver's side until the driver's front wheelwell, then into the engine compartment by routing the hoses alongside the transmission so that the hoses come out near the TB.
NYMADMINI
Dec 14, 2016 02:33 PM
sleek55044
Apr 21, 2016 07:05 PM
sbninja
Jan 4, 2015 05:48 PM
bebop86
May 15, 2010 07:10 PM
latte hiatus
Jun 27, 2007 03:57 PM
