R56 P0118
Old Aug 10, 2012 | 12:47 PM
palip's Avatar
palip
P0118
Maybe someone can help.Other day i noticed a coolant leak on my 07 cooper s from the thermostat assembly.After replacing and bleeding the system it now kicks out the P0118 code and the coolant fan continues to run hot or cold, any ideals?
Old Aug 10, 2012 | 02:04 PM
bluefox280's Avatar
bluefox280
* MINI DTC P0118 - Engine Coolant Temperature Circuit High
When you replaced the thermostat housing, did you replace the Coolant Temperature Sensor (CTS) as well?
The ECU is seeing too high of engine coolant temp, usually triggered by a faulty CTS.
- Erik
Old Aug 13, 2012 | 09:16 AM
palip's Avatar
palip
P0118
Yes it comes as a complete assembly
Old Aug 13, 2012 | 11:03 AM
Scooter162's Avatar
Scooter162
I bet the car is running really rough at start up. I believe the code means the thermostat is stuck open. Could be a bad temp. sensor. I had my thermostat changed and it had a bad sensor right from the factory. If you have the old thermostat try changing the new sensor with the old and see if it still runs rough and throws a code.
Old Aug 13, 2012 | 12:33 PM
palip's Avatar
palip
Got another new assembly gonna change it again
Old Aug 13, 2012 | 02:13 PM
palip's Avatar
palip
Replaced and still have the same problem fan runs as if overheating. Starts right up and runs smooth but kicks out P0118 in seconds. Man the reason i replaced this unit was to fix a coolant leak and ive caused more problems for myself, do i need to recode something? Thanks guys for any helpful advice.
Old Aug 14, 2012 | 08:00 AM
ellinara's Avatar
ellinara
I just changed my thermostat. No codes, no nothing! Maybe you need to bleed it out more? I remember when I changed my thermostat I had to top up the coolant 3-4 times (while bleeding the system). Could it be possible that an air buble or something is there? Or it might be that one of your tubes are clogged and maybe thats what caused the coolant leak in the first place?
Old Oct 6, 2013 | 05:08 PM
thedrizel's Avatar
thedrizel
Has anyone found a solution? I have experienced the exact same issue today and need help.
Old Jul 20, 2015 | 08:23 PM
chicano1000's Avatar
chicano1000
thermostat housing
me too, replace the whole assembly, from mini dealer oem, it trow mw same code, any advice?
Old Jul 21, 2015 | 01:25 AM
ellinara's Avatar
ellinara
Hi everyone,
I changed my water pump and that solved the issue. However, I have heard from another member that it may be the thermostat that is causing the issue.
Hope this helps.
Old Apr 17, 2016 | 10:40 PM
DavesMini's Avatar
DavesMini
Solution to this thread-- same exact issue!
Has anyone ever received resolution on this issue. Had the water pump replaced a month ago. Replaced the thermostat housing which came with the new sponsor. Fan runs as soon as key is on and runs for10 min. After turned off. --- this is when starting cold! After a day of trying this and that with no different results I, I put in the old sensor with the same results? I'm out of solutions. Could it be a defective sensor? What else could it be?
Old Apr 17, 2016 | 10:43 PM
DavesMini's Avatar
DavesMini
The car is a 2009 Mini Cooper S JCW.
Old Aug 11, 2020 | 03:22 PM
Virgoan Blankenship's Avatar
Virgoan Blankenship
0117 to 0118
I had a very similar issue although mine was a little bit more odd.
I had to install a thermostat housing because of a leak coming from heater hose. In the process I ended up breaking my crossover pipe so I had to replace that as well. When I had everything put back together it started throwing p0117 code. So I took the new sensor out of the thermostat housing and I put the old sensor back in. Now it's reading p0118.
The P0117 suggested the temperature was below 40゚, the 0118 suggests the cars running at 286゚. A possible solution, replace the connector that attaches to the sensor. I have a 2007 R56 And it seems like just about every piece of plastic in this car falls apart the 2nd you touch it.
Old May 28, 2023 | 04:05 PM
Buggzie's Avatar
Buggzie
P0118 R56 2007 Mini Cooper S fixed
Found the green wire had broken at connector. Replaced wire loom $20usd and fixed the open connection. Started having issue after fixing leak at thermostat area and replaced housing. Symptoms fan ran all the time when vehical was running and extended time when turned off. Would throw a P0118 every reset of ecm.
orionwave1
Oct 13, 2025 05:36 PM
Raidah
Jan 12, 2015 02:14 PM
user 7398330
Nov 23, 2014 01:57 PM
AbsoluteAuto
Nov 7, 2014 05:49 AM
