Replace Front Rotors on a 2003 S ???
Old Jul 2, 2012 | 05:54 AM
cutty34's Avatar
cutty34
I looked on the how to forum on how to do it and I didn't find it .Could someone please tell me how to do it because I don't know how to get the center nut off. Do I need a special tool ?
Old Jul 11, 2012 | 04:48 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
You'll first need to remove the brake calipers.
Once they are removed, there's a screw you'll need to remove from the center section of the rotors between the lugs.
More than likely, the screw will be frozen and hard to remove....likewise, once it's removed the rotor itself will probably need coaxed off as well.
Follow guide to remove rotor (works for R50 or R53)
http://www.europeancarweb.com/tech/e...mini_cooper_s/
Remove rotors on R53
https://www.northamericanmotoring.co...s-for-r53.html
Old Jul 11, 2012 | 05:01 PM
MINIdave's Avatar
MINIdave
Do not take off the center nut, that's for the axle.
minihune's Avatar
minihune
What rotors were you going to use for replacement?
Pick one that is painted in the center hub area to reduce corrosion and rust.
Drilled and slotted more for looks, not needed for street use. Cryo treated to resist heat from track or autocross, not needed for street only use.
Some examples-
http://www.tirerack.com/brakes/resul...3&autoModClar=
See
Centric High Carbon Plain 125 Series Rotors $39 each front, $31 each rear
Brembo Plain rotors $41 each front, $50 each rear
Change brake pads as needed-
StopTech Street Performance pads $65 each front and rear pairs
For street use with less brake dust-
Akebono Euroceramic pads $65 front pair, $71 rear pair
Centric Posi Quiet Ceramic pads $53 front pair, $45 rear pair
Old Jul 11, 2012 | 08:22 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Remove wheel, then remove T50 torx bolt on center hat. If you need you can use a screw driver to keep the rotor from turning. Then use a 7mm allen to remove the caliber, and then use 16mm socket and ratchet to remove caliber bracket. After that you can smack the rotor with a hammer and it will come right off.
Check out our WMW rotors great OE quality without the high price.
http://www.waymotorworks.com/wmw-bra...0-r53-r52.html
Old Jul 11, 2012 | 09:41 PM
minihune's Avatar
minihune
looks like a pretty good set of rotors with a durable finish.
Way,
what about which brake pads you have?
Akebono Euro pads OK? $95 for both front and rear sets very good
http://www.waymotorworks.com/akebono-brake-pads.html
Old Jul 12, 2012 | 11:44 AM
WayMotorWorks
Vendor
Way,
The Akebono's are ok for a street car, but I really personally like the EBC redstuff pads.
http://www.waymotorworks.com/ebc-red...r50-53-52.html
Old Jul 12, 2012 | 12:00 PM
Capt_bj's Avatar
Capt_bj
not intending to hijack but
I've used EBC Green for years for pure street driving on my 02-S and now my 07
WAY - if you recommend red over green, why? I'm due for new pads soon.
Old Jul 12, 2012 | 12:06 PM
WayMotorWorks
Vendor
the greens are not bad pads, but I've found the reds to have better bite, and less dust. So I've switched many customers from Green to red and the general response from the customers has been that they never had anything wrong with the greens, but now that they have reds they like them better.
Old Jul 12, 2012 | 03:24 PM
Eric_Rowland's Avatar
Eric_Rowland
Thanks minihune,
Just got the Centric rotors and pads for a friend. Feels better installing them with an endorsement from a long time MINI oficionado.
W0TM8
Dec 19, 2019 07:50 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Yazon
Tires, Wheels, & Brakes
11
Aug 27, 2015 04:41 PM
fjork_duf
Aug 16, 2015 04:38 PM
FLYM1N1
Aug 15, 2015 11:20 AM
